Question regarding correlation: 10Cent, Jerk, Pump characteristic curve
Post13-04-2004, 19:57    Subject: Question regarding correlation: 10Cent, Jerk, Pump characteristic curve Quote
I've noticed a slight vibration in my 1Z engine now.
Nevertheless, I once connected a 680 Ohm resistor to the ESP.
As a result, the amount of free energy has decreased from 5 to 3.8 mg.
Now, to the questions:
If I start with the 10C switched on, there will be no emergency shutdown.
Nevertheless, I am 1.17 times faster in the DZ test (9.3 seconds to 7.9 seconds).
Once, you had a "ruckeln" with tuning, which was also stronger than without, as expected.
Could it be that a 5 mg LL (lean mixture) setting is already very aggressive (perhaps the previous owner has already heavily adjusted the pump curve for the owner), and that with tuning, I can only get close to the 90-series power figures?
And that is why the 10C is not acknowledged by the EDC with a shutdown.
(The colleague's ASV reading was 4.4 mg without Box 4, and 1.4 mg with Box 4)
I am particularly bothered by the performance increase, even with (according to the Ruckel article) a series-like 3.8 mg LL dosage.
Is there anything against first (without tuning) bringing the LL-value to 4 mg (adjustment according to (Rough article) and then test the 10C thing again.
Moving the parameter via VAGCOM should always be reversible (simply enter the old value again) ????
Thank you for the tips.
Post13-04-2004, 20:17    Subject: Re: Question regarding the relationship: 10 Cent, Jerk, Pump Characteristic Curve Quote
dieselmartin wrote:
What if, instead of tuning, we first aim for an LL-value of 4 mg? (Adjustment according to...) (Rough article) and then test the 10C thing again.
Hi Martin,
IMO, there's nothing against it -> Try it out icon_smile.gif, although the risk of damage is practically zero here.
No new posts 10Cent Tuning Technical Articles
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ruckeln BPW im A4 (TDI 8V) DPF: Beschreibung und Behebung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zusammenhang AFN Ruckeln -ESP -schiefer Zahnriemen Diesel Engine Technology
No new posts Erfahrung: 10Cent am SDI Diesel Engine Technology
No new posts Erfahrungswerte 10Cent am 1Z Diesel Engine Technology
No new posts pulsierende LDA mit 10Cent Diesel Engine Technology
