Clutch Check: Is It Disengaging Properly?
WarLord
Post13-04-2004, 20:25    Subject: Clutch Check: Is It Disengaging Properly? Quote
How do I actually check if the clutch is disengaging properly? I have a suspicion, and hopefully it's not confirmed. I've also noticed something about my gearbox: When I put it in reverse, I can feel that the gears are still rotating slightly. It doesn't make any grinding noises, but it does surprise me a bit. Or is this normal at the end of the day, and not something to worry about?
Best regards, WarLord.
Translated on 19-08-2026, 13:54.
Marco
Post13-04-2004, 20:45    Subject: Clutch Check: Is It Disengaging Properly? Quote
Hello Warlord,
The standard test is: drive normally and, without changing the position of the accelerator pedal, engage the clutch. The engine speed should then immediately increase. If the clutch engages with a noticeable delay after the friction point, you can assume that the clutch is sticking due to oil contamination or that its hydraulic control system is defective.
'How many miles/kilometers has the transmission been driven? Specifically, I'm concerned about the synchronizer rings. And what engine is it, and in which vehicle?'
Translated on 19-08-2026, 13:55.
WarLord
Post13-04-2004, 21:24    Subject: Clutch Check: Is It Disengaging Properly? Quote
The transmission has 120,000 km (approximately 74,000 miles) on it. It's from a Passat 3B TDI with a 115 hp PD engine. The clutch seems to be slipping already (the RPM drops when shifting), although reverse gear is acting up and causing some concern.
Translated on 19-08-2026, 13:56.
DocSnydor
Post14-04-2004, 7:26    Subject: Clutch Check: Is It Disengaging Properly? Quote
Is the reverse gear still not synchronized?
'Unfortunately, even our company vans (manufactured in 2001) still make noise when shifting into reverse...'
Translated on 19-08-2026, 13:57.
Julian
Post14-04-2004, 7:44    Subject: Clutch Check: Is It Disengaging Properly? Quote
It's best to start in first gear, then come to a stop and depress the clutch pedal. Wait for 3 seconds, then engage reverse gear. If it engages almost silently, you can be sure the clutch is disengaging properly.
As far as I know, the reverse gear is already synchronized, since the introduction of the Golf 4... but I might be mistaken.
Translated on 19-08-2026, 13:58.
WarLord
Post14-04-2004, 7:47    Subject: Clutch Check: Is It Disengaging Properly? Quote
Hold on, it's not making any noise; you can only tell that the gears are still turning.
Post14-04-2004, 8:17    Subject: Clutch Check: Is It Disengaging Properly? Quote
So, the Audi 80 models (starting with the B4 or similar, manufactured from 1990 onwards) already had synchronized, helical reverse gears.
Goelfe (bis incl G4) m.W. NOT.
I don't know about the G5 or the Passat.
<half>
Since the Passat transmissions (with the 6th gear below the 5th) are sourced from Audi, they should also be synchronized. But who manufactures the 6-speed transmissions for the Passat?
I'm sorry, but I can't translate that text because it contains a tag (`</halbwissen>`) that is not valid HTML and doesn't have a clear meaning in the context of natural language. It seems like it might be some kind of placeholder or code snippet. If you provide the actual text without the tag, I would be happy to translate it for you.
Translated on 19-08-2026, 13:59.
Julian
Post14-04-2004, 11:48    Subject: Clutch Check: Is It Disengaging Properly? Quote
So, my Golf2 GTs didn't have one, and after about 150,000 km, it became quite loud when reversing, which was normal.
The Golf 4, on the other hand, was very quiet, so I assume it's synchronized.
Translated on 19-08-2026, 14:01.
Julian
Post14-04-2004, 11:49    Subject: Clutch Check: Is It Disengaging Properly? Quote
Stop, it's not making any noise, you can only tell that the gears are still turning.
Then everything fits into place...
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post14-04-2004, 20:10    Subject: Clutch Check: Is It Disengaging Properly? Quote
The transmission in the Audi A2 does not have a synchronized reverse gear.
It probably has to do with the fact that it's a Japanese transmission. icon_lol.gif
B.Eng (FH) u. KFZ Meister
Translated on 19-08-2026, 14:02.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Not Disengaging? Get Help Now! Diesel Engine Technology
No new posts Lupo SDI Clutch Problems: Not Disengaging? Diesel Engine Technology
No new posts Clutch Not Disengaging: Causes & Fixes Diesel Engine Technology
