Hi everyone,
As promised, here's a new measurement series with a higher sampling rate (measurement interval of approximately 0.45 seconds), and most importantly, measurements taken both forwards and backwards on the same track, with multiple repetitions. A total of nine measurements were taken, which I have also semi-automatically analyzed, and which I would of course like to share with you. The raw data can be found, as always, in
http://www.informatik.hu-berlin.de/~richling/tmp/.
The actual data file is LOG-01-011-xxx-xxx.CSV; the other CSV files and the files labeled "versuch" are from a previous run. The serie2.xls file contains the calculations for the residence times (a simple proportional calculation is used to determine the times corresponding to 2000 and 4000, respectively), and the remaining files are images, which I will also include below in PS and PNG format. Explanations will follow shortly.
In the original CSV file, the first column contains "BRANDS," which makes it easier to find the acceleration tests, and also provides additional information.
The test setup was as follows:
Ibiza with ASV (Anti-Slip System), unladen weight 1240 kg. With driver (60 kg) and fuel tank 2/3 full, the actual weight is likely around 1230 kg, possibly a bit more due to the trailer hitch. Air temperature: 20 degrees Celsius. Coolant temperature: 91 degrees Celsius. Driven for a very long time to warm up. Mileage: 10300 km. AGR (Active Grille Roller) is active. No tuning modifications.
My track is about 2 km long, with a slight curve in the middle, and I made one attempt before and one after the curve. I'll call the first section "1" and the second section "2". The driving directions are a (roughly westward) and b (opposite). If there was wind (subjectively, there wasn't), then all the "a" attempts would experience it the same way, and all the "b" attempts would experience it in the opposite direction. Therefore, the names of the attempts are constructed as follows:
Direction number.
So, "1b2" represents the second attempt on track 1, heading east, etc.
The correspondence to the markers in the file is as follows (number: name - calculated time):
The times were determined using a proportion based on data from the periods around 2000 and 4000, and then subtracting the results, as shown in the file "serie2.xls".
1: Test marker, no meaning.
2: 1a1 - 6.182
3: 2a1 - 6,191
4: 2b1 - 6,144
5: 1b1 - 6,073
6: 1a2 - 6,090
7: 2a2 - 6.238
8: 2b2 - 6,276
9: 1b2 - 6,107
10: 1b3 - 6,144 (I quickly added this one to the remaining section of track 1 because I was worried that I might have lifted off the accelerator too early at 1b2, which turned out to be a mistake. So, 1b2 is also valid.)
As you can see, the variation is VERY small, which speaks well of both the measurement method and suggests that the subjective impression that the tracks were level and windless seems to be correct. Otherwise, such discrepancies would be noticeable when attempting the course in the opposite direction. However, there is nowhere where either option a or b is significantly worse.
@Ulf: This time, you can clearly see how the boost pressure behaves, and just like you saw before 2000, the overshoots are also clearly visible.
If anyone has any further questions about the car, the tests, or the files, please feel free to ask. Perhaps these measurement results can help unlock the mystery surrounding the increased power and the torque curve.
Here are 9 more diagrams, each showing the engine speed (rpm) and boost pressure (ld) of the tests. The boost pressure is absolute, as reported by VAGCOM.
The order of the diagrams is as shown above, following the order of the measurements (I drove the entire route back and forth twice, which is why the order is like this).
The curves in the diagrams also have corresponding names, so if I made a typo in the link, it will be apparent from that.
1a1:
2a1:
2b1:
1b1:
1a2:
2a2:
2b2:
1b2:
1b3:
Okay, that's all for this set of measurements for now. Anyone who wants to do some calculations with it, please feel free, and anyone who wants to use it for further analysis, please feel free as well.
@Rainer: Of course, you are free to use this data for the TDI website as you see fit.
Jan.
