Diesel Injector Failure?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Snowfun
Post20-04-2004, 8:31    Subject: Diesel Injector Failure? Quote
How can you tell if a PD element is defective?
Can this [problem/issue] be caused by something like a faulty charger?
Regarding the incorrectly filled engine oil without the VW 50501 specification, I received the following statement in another forum:
If it was 'just' the turbocharger that failed, then it wasn't due to the oil. At least not in the sense that it was a specific 'PD' oil. After all, even the turbodiesels without 'PD' injection systems have them.
If one or more of the PD elements had failed, the situation would obviously be different. In that case, one would have to assume that the problem was indeed caused by the wrong type of oil.
Translated on 29-09-2026, 6:12.
Post20-04-2004, 11:42    Subject: Diesel Injector Failure? Quote
The statement is actually completely logical.
The oil should at least meet the VW 50500 standard, as this is the specification required for VW TDI engines (as far as I know, the first G1 TDI was introduced in 1983).
If it doesn't even have that, one could try to attribute any potential turbocharger damage to the absence of this standard.
Translated on 29-09-2026, 6:14.
Snowfun
Post20-04-2004, 11:47    Subject: Diesel Injector Failure? Quote
And then I also noticed that the invoice stated 4.75 liters were filled and charged, even though the owner's manual for the 1.4 TDI specifies that only 3.8 liters, including the oil filter, can fit!
Could excessive oil, after six months, potentially lead to defects?
joergs
Post20-04-2004, 20:42    Subject: Diesel Injector Failure? Quote
How many threads do we currently have discussing the same problem?
Translated on 29-09-2026, 6:15.
Julian
Post20-04-2004, 21:10    Subject: Diesel Injector Failure? Quote
Here's the main thread, that's where it continues.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts PD Element Defect: A4 B7 2.0 TDI Issues Diesel Engine Technology
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pump-nozzle Diesel Engine Technology
