1Z other injector nozzles
MichaB.
Post09-04-2004, 10:54    Subject: 1Z other injector nozzles Quote
hi,
My engine has already reached 200,000 km, but it's producing quite a bit of black smoke under load.
'Now I want to replace the fuel injectors and I've been offered some from a Golf 4. They come from an ALH engine with 66 kW. Will these injectors also fit in my older 1Z? Unfortunately, the parts catalog on the Bosch website isn't working, so I haven't been able to check there.'
I hope someone can help me with this...
Happy Easter.
micha
Translated on 10-07-2026, 2:23.
MichaB.
Post19-04-2004, 16:43    Subject: 1Z other injector nozzles Quote
hi,
I just went ahead and replaced the nozzles. It works fine, but it runs a bit louder (probably due to the slightly higher opening pressure).
I had my old nozzles checked recently, and the results were:
Not a single one has sprayed properly; three of them have dripped.
The opening pressure was still within acceptable limits.
I think that speaks for itself; anyone who has reached a mileage of approximately 200,000 km should probably consider having the injectors replaced.
Hi Micha,
Translated on 10-07-2026, 2:24.
Post19-04-2004, 17:12    Subject: 1Z other injector nozzles Quote
Thank you for the information.
What did you pay for the "reprinting" of the old nozzles (or what would you have had to pay icon_smile.gif?
I'm also thinking about getting new injectors (the engine is nearing 160,000 km).
Mainly because a nozzle is making noise (it sounds uneven when it's injecting fuel, but not during acceleration).
Translated on 10-07-2026, 2:26.
MichaB.
Post19-04-2004, 21:14    Subject: 1Z other injector nozzles Quote
hi,
The expansion was terrible... Volkswagen doesn't have any specialized tools. So I went to a friend who runs a workshop; he had a 'nozzle remover' and those things came out in no time.
When he returned the tools, he quickly sprayed some cleaner on the nozzles, but it was pointless.
I wouldn't even be able to tell you what the usual cost is. The labor involved is only 10 minutes for 4 nozzles...
Hi Micha,
Translated on 10-07-2026, 2:27.
thomas.diem
Post20-04-2004, 9:25    Subject: Fuel injectors! Quote
habe bei meinem Motor (1Z im Passat Variant Bj. 94) bisher auch ca. 170tkm runter, mir kommts in letzter Zeit so vor, als würde der Motor ohne Last, also beim dahingleiten auf der Landstrasse unrund laufen, beim Beschleunigen klingt er ganz normal, jetzt werden manche sagen, das wären die Reifen, aber wenn ich die Kupplung trete ist das Geräusch weg. Ich habe einmal vor ca. 50 60tkm den Nadelhubgeber, also die Düse des 3. Zy'Swapping binders is an old problem with the 1Z.'
However, I wasn't necessarily keen on replacing the other nozzles just based on a hunch. Is there a way to pinpoint the problem more precisely?
Thank you.
Best regards, Thomas.
Translated on 10-07-2026, 2:28.
joergs
Post20-04-2004, 9:35    Subject: Subject: Fuel injectors! Quote
Thank you.
Greetings Thomas.
Have the system checked and calibrated, and have the spray pattern inspected by a reputable Bosch service center!
Translated on 10-07-2026, 2:29.
DocSnydor
Post21-04-2004, 9:08    Subject: 1Z other injector nozzles Quote
'@ MichaB'
What kind of filters do you have installed right now? Are they the ones from ALH? Do they offer any performance improvements?
Translated on 10-07-2026, 2:30.
MichaB.
Post21-04-2004, 11:14    Subject: 1Z other injector nozzles Quote
Hi doctor,
I've now installed the injectors from ALH. They don't improve performance at all; in fact, I think they might even be a little worse in 5th gear. I foolishly didn't take any measurements beforehand. Maybe there are still some good and cheap AFN injectors out there?
Hi Micha,
Translated on 10-07-2026, 2:31.
Post21-04-2004, 13:44    Subject: 1Z other injector nozzles Quote
1Z 184 approximately 190 bar.
ALH switch 184 to 220 bar.
It's obvious that this won't improve performance; the higher pressure is supposed to help reduce vibrations.
Use ASV Duesen that have the same parts as AFN but with a pressure of 220 bar instead of 205 bar.
(according to my current understanding).
um = micrometer (I can't find "mü" here icon_smile.gif)
Translated on 10-07-2026, 2:32.
Post21-04-2004, 15:07    Subject: 1Z other injector nozzles Quote
dieselmartin wrote:
here).
µ = AltGr + m
It works, you know... icon_biggrin.gif ...at least when the keys are assigned correctly.
Translated on 10-07-2026, 2:33.
Post21-04-2004, 15:11    Subject: 1Z other injector nozzles Quote
Here's how Martin's contribution should look:
dieselmartin wrote:
1Z 184 µm 190 bar
ALH switch, 184 μm, 220 bar.
Please provide the text you would like me to translate from German to English. I will only provide the translation, without any explanations.
Translated on 10-07-2026, 2:35.
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Steuerzeiten und andere Probleme V6, AFB Diesel Engine Technology
No new posts Der Kupplungswechsel und andere Überraschungen ..... Diesel Engine Technology
No new posts @ Michael II and also others :-) Diesel Engine Technology
No new posts 1,9AAZ: andere Wirbelkammern als 1,6JR?! Diesel Engine Technology
