ObenbeiMutti wrote: |
| ...Is the assumption correct that, aside from the price, there is no difference between a 100 HP PD and a 150 HP PD, and that you can save a lot of money by electronic tuning?... |
This assumption is fundamentally wrong!
Here are the changes that come to mind right away:
- Turbocharger
- PD elements
- LLK
- Fuel cooling
- Crankshafts
- Storage
- Piston
- Engine control unit (ECU)
Okay, I'm ready. Please provide the German text you want me to translate.
Sometimes, different connecting rods and piston pins are also used.
The AXR (74kW D4) even has a completely different exhaust system design... (with a water-cooled EGR system).
You can find everything else using the search function.
Oh yes, and the 1.9-liter engine is not the "mother of all TDI engines" (see the article mentioned above).
