palmstrollo Guest
24-04-2004, 7:52 Subject: What (software) alternatives are there to VAG-COM? |
Hi.
The issue that my 1/93 B4 TDI could not be read with VAG-COM seems to be known to Ross-Tech; therefore, the problem is not with the interface. Even a professional adapter failed to establish communication with VAG-COM.
My question:
Which software can do something similar, or who could provide me with a trial version?
Thank you and best regards.
Hermann.
joergs Guest
24-04-2004, 8:11 Subject: What (software) alternatives are there to VAG-COM? |
hello hermann
Check this out.
http://www.vcds-plus.com
palmstrollo Guest
24-04-2004, 10:09 Subject: What (software) alternatives are there to VAG-COM? |
Well, it's NOT related to the PC/laptop.
When attempting the transfer using a PC, I received the same error messages: 'Too many transmission errors.'
But perhaps there will be a reference to similar diagnostic software.
Thank you.
Hermann.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
25-04-2004, 19:51 Subject: What (software) alternatives are there to VAG-COM? |
Is it working out at the workshop?
Profile PM WWW Garage |
Uwe@Ross-Tech Guest
25-04-2004, 21:05 Subject: What (software) alternatives are there to VAG-COM? |
For newer vehicles, and for Windows, there are no real alternatives. The program offered by Eichstädt-Elektronik only runs on pure DOS, not even in a Windows DOS window! It is much easier to implement the VAG protocols in pure DOS than in Windows. In pure DOS, you can directly access all hardware in the PC and even disable all interrupts. This is not possible in Windows. In 2001, I had a lot of contact with the people behind this program. They even wanted to buy my source code because they couldn't create anything at all under Windows.
Furthermore, that DOS program is useless with newer vehicles. Try using an EDC-16 engine control unit.
'With older Audi 1Z models, VAG-COM simply doesn't work with a basic interface and Windows, but that's also stated on our websites. The problem stems from the latency in the Windows driver for the serial interface.' It definitely works with a HEX interface.
-Uwe-
palmstrollo Guest
26-04-2004, 6:04 Subject: What (software) alternatives are there to VAG-COM? |
Thank you.
@Rainer
Everything is working perfectly in the workshop.
@Uwe
I had purchased the Pro3 adapter (with the intelligent interface) including the VAG-COM 403 software. But even with that, it doesn't work.
I'm slowly losing faith  .
Hermann.
christians Profi-Schrauber
26-04-2004, 11:59 Subject: What (software) alternatives are there to VAG-COM? |
Is this interface the same model as the one Rainer uses in his program, i.e., from Ross-Tech, or is it a proprietary development by Auto-Intern? Gruß Christian
Uwe@Ross-Tech Guest
26-04-2004, 13:36 Subject: What (software) alternatives are there to VAG-COM? |
The interfaces from Auto-Intern are Auto-Intern's own development. We have been supporting the 'dongle' function in these interfaces for a few months, but only Auto-Intern is responsible for the basic functions. When did you purchase this interface? I think Auto-Intern would be interested to know that it is not working with this control unit. Have you already discussed the details (exact control unit number, etc.) with Odin or Rainer?
It works with a HEX interface. HEX interfaces are available from Rainer, as well as from the distributors in Berlin and Riedenburg. Perhaps you could drive to one of them and see it with your own eyes.
-Uwe-
palmstrollo Guest
26-04-2004, 19:46 Subject: What (software) alternatives are there to VAG-COM? |
Okay, here we go.
Rainer then tested with a different laptop; initially, without success. The 'built-in intelligence' of the dongle adapter failed to establish a connection.
The following changes to the connection options were necessary for it to work:
Baud rate 240.
Block interval 125.
Symbol-Interval 3.
Since the connection via USB was more stable, I bought the USB version.
'Der schnelle braune Fuchs springt über den faulen Hund.'
@Rainer
Perhaps you could include these values in the 'Tips/Tricks' section. I'm sure I'm not the only one who's having trouble with this.
Unfortunately, I was unable to obtain any measurement values for the individual channels at home. I tested 200 channels, from 000 to 200, and each time I received the error message 'not available'  . For further analysis of the 'residual vibrations,' I would also have been interested in the idle injection quantity, air mass, and temperature sensors. Also, there is no label file available for the engine control unit 8A0 907 401B. Only the TDI graph is working; however, the fuel injection timing was fine.
Perhaps someone else has an idea about the channels...
Hermann.
26-04-2004, 20:52 Subject: What (software) alternatives are there to VAG-COM? |
palmstrollo wrote: | Okay, here we go.
Rainer then tested with a different laptop; initially, without success. |
Okay, so first of all, Emskirchen is not located near Dortmund, but rather in the area of Erlangen-Nuremberg.
2. I didn't have a Palmstrollo device, so I couldn't test anything.
and 3.
Quote: |
The "built-in intelligence" of the dongle adapter failed to establish a connection.
Baud rate: 240.
Block interval 125.
Sign-Interval 3 |
Search function. The issue with the initial baud rate on adapters without built-in intelligence on the 1Z is a known problem.
To reiterate: The dongle adapter from Auto Intern did not work, because it is not technically compatible with the one offered here in the car diagnostic shop! Quote: |
Since the connection via USB was still more stable, I bought the USB version. |
Good for you, not for me.
Quote: |
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
@Rainer
Perhaps you could include these values in the "Tips/Tricks" section. I'm sure I'm not the only one who is having trouble with them.
Quote: |
Unfortunately, I was unable to obtain any measurement values for the individual channels at home. I tested 200 channels, from 000 to 200, and each time I received the error message "not available" . For further analysis of the "residual knocking," I would have also been interested in the idle injection quantity, air mass, and temperature sensors. Also, there is no label file available for the engine control unit 8A0 907 401B. Only the TDI graph works; however, the injection timing was okay.
I would say, you should ask the professionals from whom you bought your adapter.
Here's an adapter where everything works without having to fiddle around with the program options like crazy. How many hours would you have wasted in the workshop, unable to help the customer?
With that, one could have avoided all the trouble:http://shop.dieselschrauber.de/product_info.php/products_id/46
That's the one that Uwe was talking about.
Thank you to ChristianS for the perfect setup; that was exactly the right question.
Translated on 26-08-2026, 9:19.
