Hi Monster.
Please provide us with more detailed information.
- What type of TDI engine is it (1Z, AHU, ALE, AFN)? (This is indicated in the service booklet).
- What does "air mass meter OK" mean? What values does it display? How did you measure it?
- Have you already done a dyno test? (Run the engine from 2000-4000 RPM in 3rd gear, fully depressing the accelerator pedal from 1500 RPM).
- High RPM and a speed of 130 (in which gear)? In 5th gear, that should be around 2800 RPM.
If you have data, we can say more.
Greetings.
m; Transparency, Teamwork
