small addition: after everything was fine for three days, it's not starting again
. I just got the error code from the last time it wouldn't start, and surprisingly:
Error text: 1268, quantity adjustment device.
signal error.
implausible signal - sporadic
According to the workshop, the possible cause is:
flow meter malfunction.
faulty regulator.
throttle valve defective.
Pump failure.
Control unit defective.
I would like to know if it's possible to control the signal box, and also the track selector and switch. I don't want to be told again that it starts up perfectly fine!
