Gearbox letter codes correspondence
Bolzer
Karma: +14 / -0   Thank you, like it!
Post16-05-2004, 22:49    Subject: Gearbox letter codes correspondence Quote
Hi.
I'm planning to extend the 5th gear on my EGS gearbox. I've already found some information using the search function, but I also found two more gearboxes on a list that have an even smaller ratio: the DRZ and the DUS gearboxes. Now my question is: which engines are these gearboxes designed for?
Best regards, Bolzer.
Translated on 12-07-2026, 17:31.
No new posts VW Car Engine Codes: Type, MKB, GKB, AKB, MJ Technical Data
No new posts VW Commercial Vehicle Type Designation, Engine Code, Gear... Technical Data
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Turbocharger Part Number Cross-Reference (AFN) Diesel Engine Technology
No new posts Brake line routing on the ABS hydraulic block Transmission, Chassis, Body & Interior
