Engine Control Unit (ECU) & Replacement Engines
flaufer
Post18-07-2002, 8:52    Subject: Engine Control Unit (ECU) & Replacement Engines Quote
HiYa!
Sure, here's the translation:
'Just a quick question for clarification:'
I received a new V6 TDI engine from Audi (a replacement engine) as a gesture of goodwill (see another thread), and now I'm not sure how to gather the following information.
a) Every engine is different, meaning that each engine control unit (ECU) has a calibration map that is individually tailored to the specific engine block and mechanics (that's why many tuners want to read out the old data to adapt the new one) - is that correct?
b) My engine was replaced, will the engine control unit (ECU) with the mapping optimized for the old engine also be replaced?
c) If b) doesn't..., then it doesn't really fit together, does it?
d) I suppose a control unit reset probably won't change anything about the engine mapping, right?
Am I getting something mixed up here? Or is the engine control unit (ECU) always so closely connected to the engine that it also needs to be replaced?
Felix.
Translated on 22-10-2026, 3:17.
Rudi
Post18-07-2002, 11:51    Subject: Engine Control Unit (ECU) & Replacement Engines Quote
Hi Felix,
a) It's conceivable (at least with the newer, system-programmable engine control units), but I don't believe that manufacturers perform dyno tests on every vehicle.
In older vehicles, the greatest potential for tuning improvements lay in the uniformity and universality of the engine control maps, which were designed to work across a wide range of conditions, from Siberia to the Sahara, and with all types of fuel.
I suspect that the tuners are reading the ECUs to ensure they are using the correct data for the configuration.
b) If individual adjustments are indeed necessary, the engine control unit (ECU) may need to be tuned to the engine. I don't think a new ECU is necessary.
c) Yes, see b).
d) No, that would be disastrous. Disconnecting the battery every time would lead to icon_smile.gif a completely different driving behavior. A possible solution would be to set the parameters to default values (via a software command) so that it works even without individual adjustments (if such a feature exists).
Translated on 22-10-2026, 3:20.
Michael II
Post18-07-2002, 12:01    Subject: Engine Control Unit (ECU) & Replacement Engines Quote
If adjustments are necessary (due to unfavorable accumulation of tolerances), this will be addressed through adaptation channels (see the error database for details on adaptation channels).
Tschüss
Michael II
Translated on 22-10-2026, 3:21.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW 1Z Engine Replacement | Exchange Motor Diesel Engine Technology
No new posts T3 Engine Swap: Which One Is Right? Diesel Engine Technology
No new posts AWX Piston Damage: AVF Engine Replacement On-Board Diagnostics (OBD)
No new posts Engine Failure: Replacement Engine & Chip Tuning Diesel Engine Technology
