Audi A6: 99 AFB Engine Stalling - Troubleshooting
diesel7
Post01-06-2004, 10:44    Subject: Audi A6: 99 AFB Engine Stalling - Troubleshooting Quote
'As I was driving on the country road at approximately 80 km/h and tried to accelerate, nothing happened. Since then, the engine hasn't shown any signs of life. I read the error memory, but there are no error codes! I checked relay 109, and the diesel supply is working correctly. When I disconnect an injector line and crank the engine, diesel flows out in two bursts per revolution (without pressure, I can hold it back with my finger). Who can help me? I'm at a loss.'
Translated on 22-09-2026, 10:09.
Post01-06-2004, 10:52    Subject: Audi A6: 99 AFB Engine Stalling - Troubleshooting Quote
Did you also read the error memory from the pump control unit, not just the one from the engine control unit?
diesel7
Post01-06-2004, 11:10    Subject: Audi A6: 99 AFB Engine Stalling - Troubleshooting Quote
I have a diagnostic device from VFL! It should be able to recognize and read out all control units. However, I can't select the pump control unit individually. Does it even have its own fault memory?
Translated on 22-09-2026, 10:10.
Post01-06-2004, 21:12    Subject: Audi A6: 99 AFB Engine Stalling - Troubleshooting Quote
diesel7 wrote:
I have a diagnostic device from VFL! It should recognize and read out all control units. However, I can't select the pump control unit individually. Does it even have its own error memory?
Translated on 22-09-2026, 10:11.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post02-06-2004, 7:11    Subject: Audi A6: 99 AFB Engine Stalling - Troubleshooting Quote
It sounds like the VP has resigned.
If the piston seizes, the engine will simply stop running and won't start again. It's practically like turning off the fuel valve icon_rolleyes.gif.
You can re-check everything from the timing to the throttle potentiometer, but it won't make a difference because diesel is already reaching the injectors.
Unfortunately, there is not enough icon_wink.gif to open them.
B.Eng (FH) u. KFZ Meister
Translated on 22-09-2026, 10:13.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Stalling: Causes and Solutions Diesel Engine Technology
No new posts T4 2.5 TDI ACV Engine Failure While Driving Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts VW AFN Engine in Audi 80 TDI Diesel Engine Technology
