Window Motor Power Consumption
wolfi_b
Post31-05-2004, 21:12    Subject: Window Motor Power Consumption Quote
Hello!
I want to install a comfort closing function for the windows and sunroof in my Audi B4. However, I need the power consumption for the window lifters. (Unfortunately, the current measurement range of my multimeter is broken icon_cry.gif).
I would be very grateful if someone could tell me the power consumption figures for driving, for blocking a window, and, if possible, for the sunroof.
Thank you very much, Wolfi.
PS: If someone could help me, I would also be willing to post the circuit diagram here.
Translated on 26-10-2026, 3:24.
wolfi_b
Post01-06-2004, 12:36    Subject: Window Motor Power Consumption Quote
Does absolutely no one among you have a little bit of extra time and a clamp meter lying around at home? icon_cry.gif
Translated on 26-10-2026, 3:25.
Gremlin
Post01-06-2004, 14:40    Subject: Window Motor Power Consumption Quote
neither / nor...
'But I'm already expecting peak currents of around 20-30 amps...'
Note: Thermos fuse, rated current (In) = 30A, cable cross-sectional area = 2.5 sq mm.
besides: what time do you expect a response on a holiday? ordinary people have to work, and they can't run out in the middle of the night to measure currents icon_rolleyes.gif.
CU Gremlin.
Translated on 26-10-2026, 3:26.
joergs
Post01-06-2004, 18:35    Subject: Window Motor Power Consumption Quote
What's going to happen now?
Translated on 26-10-2026, 3:27.
gerbi
Post01-06-2004, 20:58    Subject: Window Motor Power Consumption Quote
I'm just going to blindly suggest an automatic 'window-open-when-unlocking' system icon_smile.gif.
wolfi_b
Post02-06-2004, 6:56    Subject: Window Motor Power Consumption Quote
To the best of my knowledge, there's a 20A fuse installed. However, that doesn't really tell us anything about the current draw.
Translated on 26-10-2026, 3:28.
Lucas
Post02-06-2004, 9:11    Subject: Window Motor Power Consumption Quote
I build circuits like that too...
'On my B4, I'm getting around 6-8 amps with the window open and approximately 15 amps when it's fully closed.'
The values depend on factors such as temperature, friction, voltage (motor on/off), and direction of movement.
How do you plan to detect electrical faults in an emergency situation?
Greetings.
Lucas.
www.jalt.de
Translated on 26-10-2026, 3:29.
wolfi_b
Post02-06-2004, 9:19    Subject: Window Motor Power Consumption Quote
"Thank you very much!!"
That's exactly the information I was looking for.
About a shunt resistor and a comparator...
But the much bigger problem is this: Where can I find relays with 2 changeover contacts that can handle at least 15A? I haven't been able to find any so far!
Greetings, Wolfi.
Translated on 26-10-2026, 3:30.
Lucas
Post03-06-2004, 13:09    Subject: Window Motor Power Consumption Quote
ACT212 from NAIS/Matsushita.
You can find them, for example, at Conrad, but only through ordering.
Wiring diagram: see www.jalt.de
Martin R
Post05-06-2004, 13:13    Subject: Window Motor Power Consumption Quote
But the much bigger problem is the following: Where can I get relays with 2 changeover contacts that can handle at least 15A?
'Ideally, every Bosch service center should have this item in stock or be able to order it.'
Translated on 26-10-2026, 3:31.
Gremlin
Post06-06-2004, 18:16    Subject: Window Motor Power Consumption Quote
Okay, here's a different question: Does the B4 model not have something like keyless entry with a key lock in the door?
keyword: Volkswindow and clones...
Cu Gremlin.
wolfi_b
Post06-06-2004, 20:08    Subject: Window Motor Power Consumption Quote
Wiring diagram, see www.jalt.de
Well, it doesn't have two needles, but I might be able to rearrange the stitches...
Martin R wrote:
Every Bosch service center should ideally have these items in stock or be able to order them.
Gute Idee!! Okay, here's the translation:
Thank you.
Gremlin wrote:
Once again, a different question: Does the B4 not have something like comfort locking via a key in the lock?
Gremlin wrote:
keyword: Volkswindow and imitations...
Translated on 26-10-2026, 3:33.
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Doku Luop 6X1 MJ 2002, Window regulators stiff Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power consumption of a Volkswagen Golf 4 TDI, manufacture... On-Board Diagnostics (OBD)
No new posts Current Consumption: Idle State of Control Units - ~30mA Diesel Engine Technology
No new posts Electric Window Driver Door Diesel Engine Technology
No new posts Polo 9N window lifter On-Board Diagnostics (OBD)
