How can I find out if my MSG is up to date?
jaison
Post07-06-2004, 15:15    Subject: How can I find out if my MSG is up to date? Quote
This is a Volkswagen Golf 4, 1.4 16V (engine code: APE).
Can I read the software version using VAG-COM? Is it possibly a 4-digit number? In my case, it would be 3014. How do I find out if there's an update available?
Since I'm not a regular customer, they always put up obstacles and want to charge 70 euros just for the inspection, which I think is excessive.
Best regards, Jaison.
Julian
Post07-06-2004, 15:32    Subject: How can I find out if my MSG is up to date? Quote
Counter-question: Why would you want to do that? Are there any problems with the engine?
PrivatBereich
Post07-06-2004, 15:38    Subject: How can I find out if my MSG is up to date? Quote
Yes, the software version is a four-digit number. Here's how you can find out if there's a newer version than 3014 for your ECU icon_question.gif icon_question.gif icon_question.gif.
Why don't you ask in the CT forum ? Maybe they know more.
Private.
EDIT: I see you already did that an hour ago...
jaison
Post07-06-2004, 15:45    Subject: How can I find out if my MSG is up to date? Quote
No, there are no real problems.
'It's just the rough engine sound and the short ringing noise when accelerating that bother me.'
The knocking control system can retard the ignition timing by up to 8° for gasoline with a research octane number (RON) of 95.
I would like to know if the number 3014 is a software version number, and if there is a newer version available.
Best regards, jai.
No new posts Check mileage: How to verify car mileage Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Mileage: Read Odometer Data Easily On-Board Diagnostics (OBD)
No new posts Audi A4 B7: Exhaust Tips, No DPF, 2.0 TDI BLB On-Board Diagnostics (OBD)
No new posts Pressure Relief Valve V71: Where to Buy? Transmission, Chassis, Body & Interior
