Power Steering: Types, Benefits & Repair | Posts 16+
Go to page: Previous  1, 2
Andy
Post03-06-2002, 7:46    Subject: Power Steering: Types, Benefits & Repair Quote
Hi Eike,
First of all, congratulations on the functioning power steering icon_biggrin.gif.
If I understand correctly, this new pump is actually the second replacement, right?
What about the first pump? Was it a manufacturing defect, or did it break down due to some other reason (possibly running dry?)?
Translated on 30-08-2026, 19:27.
Arne
Post03-06-2002, 7:48    Subject: Power Steering: Types, Benefits & Repair Quote
Hi Eike,
I will definitely check to see if the oil is circulating in the expansion tank as soon as the engine is ready to be driven again.
I really don't want to have to replace the steering rack again...
Until then... have a great start to your week.
Arne.
Translated on 30-08-2026, 19:28.
eike
Post03-06-2002, 11:14    Subject: Power Steering: Types, Benefits & Repair Quote
Hi Andy,
es ist die 2te Pumpe im Austausch. Wieso die erste aufgegeben hat, weiß ich nicht. Vielleicht waren ein paar Lamellen verklemmt. Who knows...
In my opinion, the problem was not caused by a dry run, because I had added oil before starting the engine, and the pump was initially working but then failed after a short time.
On the other hand, you never know what kind of defect the pump might have had before. It's a replacement part with a label indicating 'remanufactured,' meaning it has been refurbished.
Whatever... it's working again icon_smile.gif).
Eike.
Translated on 30-08-2026, 19:29.
Arne
Post22-07-2002, 8:48    Subject: Power Steering: Types, Benefits & Repair Quote
Yay! Mine is working again too.
Es war die Servopumpe. Neue eingebaut. Oil topped up.
Chocked up and turned back and forth 10 times.
Great! Now I can finally steer again.
Arne.
Translated on 30-08-2026, 19:30.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts TDI Timing Chain Replacement Guide A4 Diesel Engine Technology
No new posts Servo Oil: Harmful to Rubber and Tires? Diesel Engine Technology
No new posts Timing Belt & Serpentine Belt Replacement - Audi A2 1Z Diesel Engine Technology
No new posts Servo / Steering is making a noise on the A6. Diesel Engine Technology
