Engine Misfire 1.0L - Troubleshooting Tips
Jan03
2010 Volkswagen Polo
Post20-06-2004, 21:57    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
Hi.
I've already experienced the uneven running and hammering sound on one cylinder in my 1Z engine. It's especially noticeable under load, and the strange thing is that the louder it gets, the colder the engine block is. I'm worried that in winter, when it's -10 degrees Celsius, it might explode, but when it reaches operating temperature, it almost disappears (you really have to listen closely to hear it).
I've already replaced all 4 injectors with new ones, and recently I also replaced all 4 pressure relief valves on the pump with new ones, but nothing has changed; it still hammers. The idle fuel quantity is 6mg, which I assume means the pump isn't worn out, and it also starts up immediately without any problems. The idle speed control sometimes shows slightly different values, but on the next measurement, they are normal again. icon_rolleyes.gif
I'm slowly running out of ideas. It probably can't be the hydropneumatic suspension, because in case of a defect, they should just make a clicking sound, and that shouldn't be load-dependent, or am I mistaken?
What the hell else could possibly be going on?
Greetings.
Jan.
Volkswagen Golf 3, 1Z engine, 165,000 km, 1994.
Translated on 29-08-2026, 13:59.
olli
Karma: +46 / -0   Thank you, like it!
Post20-06-2004, 23:56    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
The knocking sound could actually be coming from a faulty hydraulic lifter. Try using a stethoscope (a long screwdriver) and listen near the valve cover to pinpoint the exact source of the knocking. In my car, the lifter for the vacuum pump (which is driven by the camshaft in the 5-cylinder engine) makes similar noises, and it's difficult to distinguish it from a faulty lifter; however, the noise temporarily disappears if you pump the brakes a few times. Does the noise still occur if you turn off the engine for 20 minutes while it's still warm and then restart it, or is it actually directly dependent on the temperature?
Best regards from Berlin.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 29-08-2026, 14:01.
Jan03
Post21-06-2004, 7:35    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
Hello.
After 20 minutes, it starts up again slightly, but by then the engine isn't completely warm yet.
It's probably not the vacuum pump. Pressing the brake pedal doesn't seem to make any difference.
Furthermore, I have a problem: I failed the emissions test (Rust test) at the SYN (which is the equivalent of the TÜV in Denmark). When the engine is idling, there's a lot of smoke coming out of the exhaust. Is this normal, or should I be concerned?
I suspect that one of the valves isn't sealing properly, and that the hydraulic lifters compensate for it to some extent when the engine is warm.
Jan.
Translated on 29-08-2026, 14:03.
wolfi_b
Post21-06-2004, 7:42    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
The 1Z also has a rotary vane pump that is driven by the auxiliary shaft icon_wink.gif.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 29-08-2026, 14:04.
Post21-06-2004, 16:28    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
Jan03 wrote:
I suspect that one of the valves is not closing properly, and that the hydraulic lifters compensate for this to some extent when the engine is warm.
Have you ever measured the compression, or at least performed the "Hoppeltest" (-> used car buying tips)?
Translated on 29-08-2026, 14:05.
Jan03
Post21-06-2004, 20:39    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
ulf wrote:
Have you ever measured the compression, or at least done the "Hoppeltest" (-> used car tips)?
I haven't done that yet, but it's next on my list. Unfortunately, there isn't a hill or mountain nearby for the hopping test.
I'll give Bosch a call tomorrow. They should hopefully have a compression tester.
/Jan
olli
Post21-06-2004, 23:11    Subject: Engine Misfire 1.0L - Troubleshooting Tips Quote
If a valve is indeed not closing properly, you might be able to detect it (if it's an exhaust valve) by holding your hand near the exhaust pipe while the engine is running. You should be able to feel a noticeable increase in the exhaust flow speed, pulsating in time with the "hammering" sound.
But also an intake valve that no longer opens properly (due to a faulty hydraulic lifter).
can lead to a lack of air supply to a cylinder, which in turn can cause soot formation.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 29-08-2026, 14:08.
No new posts Unrunder Motorlauf VR6 AXK Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire at High Temperature (PD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low Performance, High Fuel Consumption, No Ideas? Diesel Engine Technology
No new posts Audi 3.0 TDI ASB starts very poorly, no more ideas! Diesel Engine Technology
No new posts Unrunder Leerlauf beim AFN On-Board Diagnostics (OBD)
No new posts Passat TDI ATJ keine Leistung mehr On-Board Diagnostics (OBD)
