Injector Nozzle Size 1Z: Diameter Guide
BALDUIN
Post23-06-2004, 17:49    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
Hello everyone,
I recently bought a 1Z engine as a donor for parts for my own car. When I was removing the fuel injectors, I noticed that they look different from the ones in my engine; they are slightly shorter.
They also have a different injection pressure, namely 246 bar. The ones I currently have only have 190 bar! I have now searched through all of your posts, but I haven't found any information about what hole diameter these 246 bar nozzles have.
For your information, the part number is: 028 130 201.
On the Bosch website, I can only find information about the injection pressure, not about the hole diameter. If it helps, these injectors were used until 8/92.
I'm hoping for your answers, and that I can give my rather sluggish Audi B4 Avant a bit more power with these injectors. Of course, with further modifications!
Thank you in advance!
Translated on 17-09-2026, 9:33.
WarLord
Post23-06-2004, 21:37    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
Is that already a nozzle with a hole?
Best regards, WarLord.
Translated on 17-09-2026, 9:34.
donalexo
Post23-06-2004, 22:28    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
That sounds like it might be a combination of single-feather and nozzle holders.
It is likely that the two-stage injection system was only introduced as part of further development and stricter emissions regulations.
The opening pressure you mentioned, 246 bar, also falls between the pressures of the first and second stages in the two-spring nozzle holder combinations.
As I mentioned before, these are just my assumptions and not confirmed information.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 17-09-2026, 9:35.
wolfi_b
Post24-06-2004, 7:45    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
I agree with donalexo!
It is a single nozzle made of feathers.
To my knowledge, these were only installed until June 1992.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Post24-06-2004, 8:44    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
Sure, here's the translation:
"P.S."
Part number 028 130 201 doesn't tell you anything specific about Golf 3 DI injectors, because they are all labeled that way.
The most important thing is what comes after the letters!
There are many different nozzles available for the VW Golf 3.
AEY
1Z, AHU
ALE
AFN.
They are all four different.
Therefore, please always include the letters in question.
Thank you.
Translated on 17-09-2026, 9:37.
Rudi
Post24-06-2004, 10:38    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
Another afterthought icon_cool.gif.
There were also instances of '028 130 201' without anything following it. It originated towards the end of the last millennium.
The spare parts catalog is no longer in print, but can still be obtained through the 'Classic Parts Service.'
Best regards, Rudi.
Translated on 17-09-2026, 9:38.
Post24-06-2004, 10:51    Subject: Injector Nozzle Size 1Z: Diameter Guide Quote
Okay, then I've learned something too.
At the end of the JT process, I had nozzles spraying into the swirl chambers.
And my "good source" is more up-to-date icon_smile.gif.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Fuel Injector Nozzle Size 0.216mm - 2.5L Diesel Engine Technology
No new posts Piston Slap: High-Pressure vs. Bore Diameter Diesel Engine Technology
No new posts ALE Nozzles: Size, Pressure, and Specs Diesel Engine Technology
No new posts AEY Injectors: High Quality & Performance Diesel Engine Technology
