Injector Failure: VW 2.5 TDI AKN Repair Possible?
altonno
Post25-06-2004, 19:57    Subject: Injector Failure: VW 2.5 TDI AKN Repair Possible? Quote
Hello guys,
I have a fault code in the diagnostic memory of my 2.5 TDI (AKN) engine that cannot be cleared: "Injector control valve - interruption or short circuit."
"Does anyone have any experience with this? Is it likely due to a cable issue or is the nozzle probably defective? A new one costs about €480, and there's no option for replacement parts. Is there any way to repair it, or can you find it cheaper somewhere?"
"Hello."
AL
Translated on 23-08-2026, 12:36.
SeatArosa1.7SDI
Post25-06-2004, 20:06    Subject: Injector Failure: VW 2.5 TDI AKN Repair Possible? Quote
Before asking about the NHG price, first check if the cable and the NHG unit are electrically sound. Possible causes of failure include a broken cable, chafing and short circuit, or a problem with the plug connection.
At best, it will cost you one pair of dirty hands.
You can find suggestions in the thread.
/viewtopic.php?t=5866
Translated on 23-08-2026, 12:37.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Repair: Is it Possible? Diesel Engine Technology
No new posts VAG-COM Error 00550: Needle Lift Solenoid Repair On-Board Diagnostics (OBD)
No new posts Missing needle lift sensor on AKN 2.5 TDI On-Board Diagnostics (OBD)
No new posts A4 B6 Network Control Unit Malfunction? Is a test possible? On-Board Diagnostics (OBD)
