dj1 Guest
23-06-2004, 8:49 Subject: Clutch for High Performance: Which One? |
I'm planning to install a VNT17 turbocharger in my Golf III AFN and then adjust the engine software accordingly.
I already have those nozzles installed (T4, size 216).
The performance will then be approximately 150-160 horsepower (hopefully  ).
The original clutch probably won't last very long.
What clutches do you recommend/use?
DJ.
Translated on 28-08-2026, 0:33.
Arne Guest
23-06-2004, 9:02 Subject: Clutch for High Performance: Which One? |
I also drove the AFN with a 17-inch turbocharger and a chip. My clutch had 120,000 kilometers on it and handled it quite well. I think 150-160 horsepower is no problem for the standard clutch if treated reasonably.
I wouldn't worry about that for now... unless you actually need a new one.
arne
Translated on 28-08-2026, 0:35.
dj1 Guest
23-06-2004, 9:20 Subject: Clutch for High Performance: Which One? |
arne
Hi Arne!
ok, if the time comes, I'll ask again  .
I now also have 120,000 km on my car.
Did you also do the renovation that I'm planning?
DJ.
Translated on 28-08-2026, 0:36.
Arne Guest
23-06-2004, 9:24 Subject: Clutch for High Performance: Which One? |
Hi dj1,
I didn't do the complete conversion. In one car, I had a chip and a 17-size turbocharger, and in the other, I had injectors and a chip (with a standard VNT15 turbocharger).
Good luck.
arne
'If the clutch is slipping, it's often not directly due to the clutch itself, but rather to a leaking seal that allows oil to reach the clutch. I've experienced this twice.'
Translated on 28-08-2026, 0:37.
dj1 Guest
23-06-2004, 9:56 Subject: Clutch for High Performance: Which One? |
What about the seals (brass screws, gaskets between the manifold and turbo, etc.)?
Can I buy those from VNT15, or do I need to get them from somewhere else?
DJ.
Translated on 28-08-2026, 0:38.
Arne Guest
23-06-2004, 10:14 Subject: Clutch for High Performance: Which One? |
You can use the parts from the 15-liter engine. I reused all the old parts in my engine. At least, that works with the transversely mounted AFN engine.
arne
Translated on 28-08-2026, 0:39.
Warmduscher Guest
26-06-2004, 10:35 Subject: Fichtel Sachs Clutch: Performance & Quality |
At F & S (part of the Mannesmann Group), there are various specialized clutch kits available, ranging from reinforced clutches to racing versions with bonded sinter linings and without torsional or axial springs.
For a relatively low price, people in Schweinfurt also manufacture clutches to order.
Happy switching!
G.
Bertil Profi-Schrauber
26-06-2004, 14:27 Subject: Fichtel & Sachs Sport Clutch: Performance Upgrade |
Warmduscher wrote: | | F & S (Mannesmann Group) |
Sorry, but the "Mannesmann Group" hasn't existed for three years already (I was actually involved with it)!
F & S was part of the ATECS division of Vodafone Technology and was sold by them to ZF, and it still belongs to ZF now.
http://www.sachs-ag.de/Gruß Bertil
Translated on 28-08-2026, 0:40.
