Hi.
I only glanced at it briefly, BUT:
Why should the key response jump around erratically if the actual pressure is perfectly following the desired pressure?
If the pressure sensor started malfunctioning and wildly adjusting the VTG (Variable Transmission Gear), everything would go haywire.
BTW: Your car runs on boost pressure, not on pulse width modulation
And the boost pressure is correct, right?
