T4 conversion, 2.5 TDI, ESP, ACV
Klausen
Post30-06-2004, 9:14    Subject: T4 conversion, 2.5 TDI, ESP, ACV Quote
I have now installed a working fuel pump in my 1996 2.5 TDI Transporter, which I borrowed from someone for the time being.
He wants to get her back eventually.
Okay, here's the translation:
"Now, my question. I need a pump with the VW part number 074 130 110 K."
Here are two more connector plugs on the diesel particulate filter (DPF). It's unlikely that you'll find many of these in good condition with low mileage anymore.
The newer pumps, starting from the year 1998 and identified by the number 074 130 115 B, look identical on the outside but only have one connector.
Can the 115B be converted (by replacing components) to a 110K so that it will work in my bus, or is there no way to make this work?
Bye.
Translated on 17-07-2026, 15:09.
No new posts A6 AKE Conversion to EU 3 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Umbau PDE Diesel Engine Technology
No new posts 1Z Refurbishment Diesel Engine Technology
No new posts B4 V6 TDI-Umbau Diesel Engine Technology
