Waterproof 2-Pin Connector
Post01-07-2004, 9:58    Subject: Waterproof 2-Pin Connector Quote
Hi.
I built a 10-cent adapter for the 8-pin ESP connector.
Unfortunately, I soldered the circuit board and the on/off switch to the adapter and installed it inside the housing.
If I want to remove this part (because of the upcoming technical inspection tomorrow), I need to cut the 2-pole cable from the inside.
"Now, a 2-pin connector that is sealed as elaborately as the 8-pin ESP connector would be the ideal solution. Then I could leave everything in place except for the ESP connector adapter."
An open 2-pole connector will not kill the inspector, will it? icon_smile.gif
Does anyone have part numbers for a connector and the corresponding cables?
Thank you.
Translated on 17-09-2026, 16:05.
joergs
Post01-07-2004, 10:41    Subject: Waterproof 2-Pin Connector Quote
Check this out:
http://www.passatplus.de/umbauteile/index.htm
Maybe you'll find something suitable. For most connectors, there are also additional parts available to make them waterproof.
Translated on 17-09-2026, 16:06.
Post01-07-2004, 10:44    Subject: Waterproof 2-Pin Connector Quote
Sure, you're welcome.
http://www.passatplus.de/umbauteile/stecker/stecker2.htm
There, exactly the right part is already smiling at me icon_smile.gif.
joergs
Post01-07-2004, 11:02    Subject: Waterproof 2-Pin Connector Quote
No new posts Connector: Types, Uses & Applications Upload
