Alfa8 Tachometer Adjustment
unnamed
Post20-07-2003, 15:58    Subject: Alfa8 Tachometer Adjustment Quote
hello,
I installed a new odometer and wanted to adjust the mileage using the program alfa8.
the program always closes.
Detection of combined instrument, then it closes.
Does anyone happen to have experience with Progi?
thx
werner
Post20-07-2003, 16:27    Subject: Alfa8 Tachometer Adjustment Quote
The search function is your friend, and you don't have to go through everything twice!
/viewtopic.php?t=2727&highlight=alfa8
unnamed
Post20-07-2003, 16:36    Subject: I know... Quote
I naturally found and read the entry beforehand.
but a solution to the problem could not be found, hence the new post.
Sorry
sonic
Post20-07-2003, 17:39    Subject: Alfa8 Tachometer Adjustment Quote
Hello!
...the aforementioned program only works with VDO speedometers that have a 93C66 type EEPROM installed - for all other types, it behaves as described above. I've tested it a few times - early Golf models (97, 9icon_cool.gif usually work.
other - System requirements:
1) IBM-compatible PC (yes, these were the days)
2) DOS Operating System (win in the DOS mode, of course, goes)
3) a genuine COM 1 interface
Now something else - although I also bought it through eBay in the past, out of ignorance, but who really needs it? The edonkey network really fulfills almost all car-related wishes...
unnamed
Post21-07-2003, 5:39    Subject: Alfa8 Tachometer Adjustment Quote
I also sucked up the mess from the donkey.
and is there a program that fits a Passat, year 2000?
thx
werner
Mc_Givertechnik
2010 Volkswagen T5
Post22-07-2003, 12:12    Subject: Alfa8 Tachometer Adjustment Quote
Hello everyone!
I'm always wondering how to get to functional software. {QUESTION} Isn't it that hard? Has anyone found anything useful in the meantime???
Greetings from a seeker...
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
sonic
Post23-07-2003, 21:37    Subject: Alfa8 Tachometer Adjustment Quote
Well, it probably depends on the fact that such programs are quite expensive and also not very common (e.g., Tachopro). Most providers also only use hand-programmable devices instead of PC/software solutions.
mozz
Post02-09-2003, 23:14    Subject: Alfa8 Tachometer Adjustment Quote
What on earth is a Tachopro box? Is it different from our interface?
The Tachopro! interface. Check somehow via code whether the version of the program that is not paid for is working or not. If a different interface is connected, you will receive the message that you have harvested!!
el_diesel
Post30-06-2004, 16:34    Subject: alfa8 Quote
Okay,
The alfa8 software only works with VW/Audi models from 1997-1999 with the EEPROM 99c66 in the instrument cluster.
Best regards
meyert
Post01-07-2004, 7:06    Subject: Alfa8 Tachometer Adjustment Quote
Hello everyone,
In a previous thread, a participant reported that he was able to get his A4 running with an Alfa8 and a 468er PC, but not with faster Pentium processors. Recently, I had the opportunity to test the Alfa8 on my A4, which is identical in terms of year and specifications to the aforementioned one, with an original IBM 486er PC. It works just as poorly as with my 600 Dell laptop.
I assume that this must be related to my interface (eBay), because I am also unable to access all control units (e.g., the comfort locking system 46 is not found, even though it is definitely present).
Greetings
Thomas
el_diesel
Post01-07-2004, 8:07    Subject: Alfa8 Tachometer Adjustment Quote
hello,
then you may not have set the COM port baud rate correctly!
Try 2400 bps
Best regards
meyert
Post02-07-2004, 7:05    Subject: Alfa8 Tachometer Adjustment Quote
With the baud rate in VAGCOM, I have played around both in the Windows system control and in the VAGCOM itself => nothing changes.
Whether the settings in the Control Panel also work in the DOS box, I don't know. However, Alfa8 definitely doesn't work with setting 2400. I could try setting the baud rate of the COM port again under DOS 6.2, if that's even possible.
Greetings
Thomas
Theresias
Post02-07-2004, 9:37    Subject: Alfa8 Tachometer Adjustment Quote
You cannot adjust the baud rate settings on that device; your interface is likely the source of the problem. If you cannot communicate with all other STG devices.
el_diesel
Post06-07-2004, 7:58    Subject: Alfa8 Tachometer Adjustment Quote
as mentioned, the alfa8 only works on the 99c66 eeprom chip.
i. d. Installed up to 1999.
This topic is locked, you cannot edit or reply. VagCOM and speedometer adjustment Diesel Engine Technology
