AGR EGT Sensor for Audi A6 2.5 TDI
Polarlarry
Post06-07-2004, 16:03    Subject: AGR EGT Sensor for Audi A6 2.5 TDI Quote
Hi there,
'On my A6 (2001) 2.5 TDI with engine code AKE, there are three rectangular holes (approximately 5mm wide) drilled into the side of the vacuum actuator for the EGR valve. I'm finding soot everywhere around these holes. Is this normal, or should I take a closer look at the actuator?'
Greetings / Larry
Translated on 25-07-2026, 17:58.
Post06-07-2004, 16:24    Subject: AGR EGT Sensor for Audi A6 2.5 TDI Quote
The holes must have been viewing ports so that you could see the plunger moving from the inside (e.g., during a self-test).
In my opinion, the result shouldn't be Russian.
That means there's a leak somewhere that shouldn't be there. It's difficult to determine how serious the problem is based on remote diagnosis alone.
Translated on 25-07-2026, 17:59.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts VTG Adjustment VNT15 with 2.5TDI Pressure Cylinder Upload
No new posts Turning a pressure vessel on a VNT20... Diesel Engine Technology
No new posts Einspritzdüsen ausbauen beim V6 2.5TDI Diesel Engine Technology
No new posts Worn Camshafts: V6 2.5 TDI Problems & Solutions Diesel Engine Technology
