AHU Engine Swap & Water Pump for VW Golf III
kapernaum
Post09-07-2004, 17:51    Subject: AHU Engine Swap & Water Pump for VW Golf III Quote
Hello everyone!
The timing belt replacement is due soon on my car, at 90,000 km.
A few questions:
Should the water pump be replaced at the same time? Is it also problematic with the AHU (Air Handling Unit)?
'If you're already taking the belt off anyway...? What's the approximate cost of a water pump?'
2) Was ist mit der KW-Schraube? Bis zu welchen BJ ist die zu beachten? Or is the AHU...?
because it's less problematic?
3) What else should one consider, if one is already doing something?
Where can I get this done at the most affordable price? I'm not going back to that other place; I wanted to have it taken care of by Bosch.
Are there any cheaper alternatives available? Like ATU or something similar?
Thank you for any advice.
Capernaum.
Translated on 10-08-2026, 6:30.
Post09-07-2004, 18:13    Subject: AHU Engine Swap & Water Pump for VW Golf III Quote
Hi there!
The water pump has nothing to do with the timing belt.
If you look into the engine compartment, you'll see that it is driven by the serpentine belt.
However, there are indeed engines where the water pump is driven by the timing chain.
I believe the KW screw should already be a 12.8 grade on the AHU.
I will not tolerate anyone dealing with old parts or repainting services!
I've dealt with various ATUs (presumably a specific company or service), and every single time, they messed something up. They didn't call back despite previous warnings about deadlines. There were multiple instances of incorrect price quotes (the price for two items was actually only for one), and sometimes they simply didn't complete the work.
Besides buying a can of oil, I won't be doing anything else there.
Translated on 10-08-2026, 6:32.
kapernaum
Post09-07-2004, 18:18    Subject: AHU Engine Swap & Water Pump for VW Golf III Quote
Oops, so I misunderstood something?!
I thought the water pump was also driven by the timing belt in the 1Z engine.
Ash on my head! / I am ashamed!
Translated on 10-08-2026, 6:34.
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI Water Pump: Installation & Repair Diesel Engine Technology
No new posts Golf 3 Drum Brakes: Maintenance or Replacement? Transmission, Chassis, Body & Interior
No new posts ZR change in PDs? Diesel Engine Technology
No new posts ZR Replacement: Is €440 a Fair Price? Diesel Engine Technology
