Airbag Warning Light On? Deactivate Airbags?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
PowerSound3L
Post11-07-2004, 15:42    Subject: Airbag Warning Light On? Deactivate Airbags? Quote
hi,
If, for example, a side airbag has a fault and the warning light is illuminated, are all airbags deactivated?
What happens if an airbag has been deployed? Are the other airbags still functional?
I mean something like that, where you can continue using the system even if one component fails, while the others still work.
greetings
Translated on 21-09-2026, 8:05.
Julian
Post11-07-2004, 15:47    Subject: Airbag Warning Light On? Deactivate Airbags? Quote
1) We've already had a search function before.
/viewtopic.php?t=5927&highlight=airbag+deactivated
Translated on 21-09-2026, 8:06.
No new posts Airbag Warning Light: VW Passat B5 A2 (2003) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Airbags After Accident - Save Money! Diesel Engine Technology
No new posts SRS Light On After Low Voltage - LT 35 2.5 TDI On-Board Diagnostics (OBD)
No new posts GRA Light Off? Seat Altea Troubleshooting. Diesel Engine Technology
No new posts ABS Light On: Troubleshooting & Fixes Diesel Engine Technology
