AFN 110ps plötzlicher Leistungsabfall bei 120-140 | Posts 16+
Go to page: Previous  1, 2
Rasergrüning
Post24-05-2004, 14:03    Subject: Quote
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
I'm happy again!!!
The thin hose that runs from the pressure pipe and connects to the STG was disconnected from the STG !!icon_wink.gif
It's running smoothly again, like a busy bee icon_razz.gif!
'But I think the VTG (Variable Turbine Geometry) could be adjusted even better. When idling, it shows a value of 980 on setting 11, but the actual value is 1020. However, during operation, under full load, etc., it constantly falls below the target value?'
Is it due to the VTG strut? How can I adjust it best?
Best regards from Chriss, who is happy again icon_cool.gif.
Translated on 11-09-2026, 14:49.
PrivatBereich
Post24-05-2004, 14:11    Subject: Quote
I'm happy again!!!
That's good to hear...
Is it due to the VTG rod?
Yeah, that's probably because you twisted the rod randomly before.
How can I best set it up?
Neee, geh mal auf Stellgliedtest. Dann sollte er das VTG schon mal von Anschlag zu Anschlag fahren. Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Then, take it for a test drive and see which maximum performance level it doesn't reach (with minimal pressure versus full pressure).
If both maximum values are reached, observe the boost pressure build-up. If there is significant overshoot, reduce the boost. If the build-up is slow, adjust it to be more aggressive.
Private.
Translated on 11-09-2026, 14:51.
Rasergrüning
Post10-06-2004, 11:11    Subject: Quote
Okay, I've adjusted it so that the actual pressure now roughly matches the target pressure in group 11. It's running really well. But in another post, I read that in the last column of group 11, under full load in 4th gear, for example, the duty cycle should be 85-90%. But in my case, it's always a maximum of 75%???? Is that bad? Also, I just bought a tuning box that you plug in front of the fuel injection pump. It's supposed to add about 20 horsepower, and it has an adjustment screw that allows you to increase the fuel injection amount, which causes it to smoke a lot. But even then, I don't notice a significant increase in power. Shouldn't you notice a clear change with both of these things?
Best, Chriss.
Translated on 11-09-2026, 14:53.
Post10-06-2004, 13:38    Subject: Quote
Rasergruening wrote:
But in another post, I read that in the last column of group 11, under full load in 4th gear, for example, the throttle position should be 85-90%. However, in my case, it's always a maximum of 75%???? Is that bad?
As long as the overdraft is always resolved quickly, it's not a big deal.
When running at full throttle, the variable geometry turbocharger (VTG) must always open further as the engine speed increases, to prevent the boost pressure from exceeding the target level. Therefore, the duty cycle also changes in order to maintain a constant pressure.
Furthermore, I recently bought a tuning box that you plug in front of the fuel injection pump. It supposedly adds about 20 horsepower, and it has an adjustment screw that allows you to increase the fuel injection amount so much that it makes the engine extremely noisy. But even then, you don't notice a significant increase in power. Shouldn't you notice a clear change with both parts, or?
"Merken" = Popometer = unreliable.
For example, take the DZR test, which is more reliable and objective icon_wink.gif.
Translated on 11-09-2026, 14:55.
Rasergrüning
Post10-06-2004, 20:20    Subject: Quote
What is a DZR test?
Best, Chriss.
Translated on 11-09-2026, 14:57.
PrivatBereich
Post11-06-2004, 8:32    Subject: Quote
What is a DZR test?
Best regards, Chriss
This is the speed calculator developed by Ulf, which has proven to be very reliable and reproducible.
It's an Excel sheet and can be found among the technical articles. Instructions on how to use it are also available in the technical articles section.
Private.
Post11-06-2004, 12:07    Subject: Quote
PrivatBereich wrote:
This is the speed calculator developed by Ulf.
Actually, it's more of a pass-through calculator icon_wink.gif.
Translated on 11-09-2026, 14:58.
PrivatBereich
Post11-06-2004, 12:15    Subject: Quote
Muh, you always have to be right, don't you icon_biggrin.gif?
Here is the link to it: /viewtopic.php?t=3939
Private.
Translated on 11-09-2026, 14:59.
Rasergrüning
Post14-07-2004, 20:16    Subject: Diesel Problems: Another Issue Arises Quote
Hello, I now have an Audi A4, model year 05/01 (the latest model) with a Pd engine and 130 horsepower. I believe the engine code is ABX, but I'm not entirely sure.
'So, the engine shakes when idling when it's cold, but very severely, which is not normal. It then has an idle speed variation of up to 300 RPM! Also, it makes a lot of noise. VW said it's the piezo injectors, but could it be something else? Oh, and when it's warm, it idles well, but if you give it a sudden burst of gas, it drops about 200 RPM a few seconds later and then runs normally again.'
There are no error codes stored in the system.
'First, the ECON function on the climate control system cannot be turned off, meaning the climate control system is no longer working. The error memory for the climate control system contains the following information:'
819
High-pressure generator G65.
29-00
Short circuit to ground.
It might be defective, or a cable might be disconnected.
Can someone tell me where this sensor is located on the car and what it's used for?
Thanks in advance, see you later...
Bitte gib mir den Text, den du übersetzt haben möchtest.
Best, Chriss.
Translated on 11-09-2026, 15:01.
Rasergrüning
Post15-07-2004, 12:25    Subject: Quote
MKB is AWX.
Translated on 11-09-2026, 15:03.
Rasergrüning
Post15-07-2004, 12:43    Subject: Quote
Okay, I now know what a high-pressure sender is used for, but can anyone tell me where that part is located on the car?
High-pressure generators.
The pressure sensor generates a square wave signal when a voltage is applied. This signal changes according to the pressure within the system.
This signal allows the downstream control units (e.g., coolant fan control unit, engine control unit) to calculate the pressure in the refrigerant circuit and, accordingly, control the magnetic clutch, the coolant fans, and the engine.
Translated on 11-09-2026, 15:04.
No new posts Sudden Battery Drain: Causes & Fixes Diesel Engine Technology
No new posts AFN Engine: Sudden Power Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Seat Ibiza 110PS TDI: Upgrade to G3 Diesel Engine Technology
No new posts Injector Differences: AHH 90hp vs. AFN 110hp Diesel Engine Technology
