Air conditioner is running.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Uwe
Post31-07-2002, 22:38    Subject: Air conditioner is running. Quote
Hey!
I have an A3 with the older air conditioning system, and my wife's A4 (model 2000) has the newer version. My car is always perfectly climate-controlled; hers always blows air from the middle vents (Mannanströmer). The temperature control works perfectly, and pressing the buttons also allows you to adjust the air distribution. However, you can't achieve a comfortable setting like in my car. Either you get cold/warm feet, or it blows air directly into your face. If you turn off the Mannanströmer or close them, it becomes noisy due to the partially closed vent, or there is no or too little air in the interior. Changing the desired temperature also doesn't correct this behavior. Can the settings of the system be changed in principle?
Best regards, Uwe
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts T4 2.5 TDI ACV: Troubleshooting & Fixes Upload
No new posts Beispiel: ARL zieht nur bis 3800 rpm Upload
No new posts RNS 510 Drains Battery: Troubleshooting Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Auto zieht nach links Transmission, Chassis, Body & Interior
