Tachometer Lights Dim? Golf IV Dashboard Repair
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
wolfi017
Post04-08-2004, 14:43    Subject: Tachometer Lights Dim? Golf IV Dashboard Repair Quote
I've noticed that the illumination on my Golf's dashboard isn't as bright as on newer 4-series Golfs icon_lol.gif! The knob for adjusting the brightness on the instrument panel is turned all the way up, and it can be adjusted normally, but it still only gets dim!
Can someone tell me something about this, or hopefully help me?
Thank you in advance!
Translated on 01-09-2026, 2:15.
wolfi_b
Post04-08-2004, 14:48    Subject: Tachometer Lights Dim? Golf IV Dashboard Repair Quote
Please check the voltage after the brightness control.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
wolfi017
Post04-08-2004, 14:54    Subject: Tachometer Lights Dim? Golf IV Dashboard Repair Quote
What should it normally be?
wolfi_b
Post04-08-2004, 15:40    Subject: Tachometer Lights Dim? Golf IV Dashboard Repair Quote
I'm not familiar with the wiring of the Golf 4, but if there's a potentiometer in the circuit, it should theoretically range from approximately 12 to a maximum of 14 volts.
There might be more to it than that, though.
The search function can also be helpful.
/viewtopic.php?t=5342&highlight=%2Atacho%2A+%2Abeleuchtung%2A
/viewtopic.php?t=1382&highlight=%2Atacho%2A+%2Abeleuchtung%2A
1993 Audi 80 B4 1Z
Translated on 01-09-2026, 2:16.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post04-08-2004, 15:53    Subject: Tachometer Lights Dim? Golf IV Dashboard Repair Quote
"As far as I can tell from my Polo, there's nothing better than a traditional potentiometer and voltage drop. It looks more like something that's pulse-width modulated. And then, using a regular multimeter to measure the output voltage won't work. I suspect that the G4 uses a similar technology, because otherwise, LEDs can only be dimmed in a rather uneven way."
pretzel
Translated on 01-09-2026, 2:17.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beleuchtung von Golf IV Tacho nicht mehr so hell! Transmission, Chassis, Body & Interior
No new posts Tachobeleuchtung Diesel Engine Technology
No new posts 3C Tachobeleuchtung immer an ? On-Board Diagnostics (OBD)
No new posts kurzes Aufblitzen der Tachobeleuchtung Diesel Engine Technology
