MFA: Instant Power Consumption / TDI: Severe Power Loss
Harry
Post28-07-2004, 21:54    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
Can someone give me a tip on where the error might be?
'On my 115hp AJM PD engine, the fuel consumption display no longer switches to liters per hour when the vehicle is stationary. Instead, it displays the last recorded 'rolling' consumption, for example, 6.5L. The display also does not update while the vehicle is stopped.'
However, using VAG COM, specifically the 'Engine Control Module' -> 'Measurement Block 15', the correct 'static' fuel consumption values are displayed (as usual, around 0.4 L/h).
However, all other indicators are normal.
Date: August 6, 2004:
After that, I also experienced occasional, significant performance drops. However, this was not related to the MFA (see below).
Translated on 29-08-2026, 11:29.
Theresias
Post29-07-2004, 2:05    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
No, this feature is only available from the 2002 model year onwards, in combination with WFS Generation 3.
Translated on 29-08-2026, 11:31.
Harry
Post29-07-2004, 18:22    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
I would swear on it, mine has already shown the l/h indicator.
But now things get even worse: Today, the engine reached its maximum RPM of 3,800 in 3rd gear!
After that, there was almost no acceleration in any gear, until I turned off the engine and turned it back on after about 10 minutes.
Well, next week I have my KD (46TKM) appointment anyway, let's see what happens.
Harry.
Theresias
Post29-07-2004, 18:28    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
I would swear on a letter and seal that mine also showed l/h.
Well, this is news to me. I've worked on about 50-80 Golf 4s so far (no, I don't adjust speedometers), and this feature wasn't available until the 2002 model year.
But now things get even worse: Today, the engine stopped in 3rd gear at 3,800 RPM!
After that, there was almost no acceleration in any gear, until I turned the engine off and turned it back on after about 10 minutes.
LMM?
Translated on 29-08-2026, 11:33.
Harry
Post30-07-2004, 15:40    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
I think you're right!
I've now also looked in the manual, driven by desperation, and it says what you said: 'It always displays the last current consumption value when the vehicle is stationary, and it's recalculated every 30 meters while driving.'
So, I guess I was probably misled by the R32 - it has the same large MFA display, and there it shows liters per hour; and unfortunately, it turns out that a neighbor of mine has a TDI MJ2002, and I compared his with mine using my MFA.
Perhaps it can be explained by Alzheimer's disease...
Subject: Performance Loss.
I also suspect the LMM.
The problem manifests as intermittent power drops across the entire RPM range. Occasionally, the tachometer also stops increasing above 4000 RPM, followed by a complete loss of power in all gears.
Next week I have a doctor's appointment, but my neighbor is going to let me try installing his mass airflow sensor (MAF) temporarily.
Translated on 29-08-2026, 11:35.
WarLord
Post01-08-2004, 12:10    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
This is the mass airflow sensor (MAF). We had the same problem with ours (in a Passat). We replaced the MAF sensor, and the car is running fine again.
Best regards, WarLord.
Translated on 29-08-2026, 11:36.
Harry
Post04-08-2004, 21:15    Subject: MFA: Instant Power Consumption / TDI: Severe Power Loss Quote
Okay, so...
KD is complete, and the faulty part causing the significant performance loss has also been identified.
In short: The LMM (Mass Air Flow sensor) was tested and, contrary to my initial assumption, was not the cause of the problem. Instead, the boost pressure sensor 1J0 906 627 A was defective. And as far as I can tell today (August 4th), the problem seems to be actually resolved.
PS: The device is located in my TDI in the engine compartment, directly below the driver's side windshield wiper linkage, has a gray body, and 3 hose connections.
'During the error code reading (engine control unit), the error '17965 Boost pressure control, limit exceeded' was displayed.'
Translated on 29-08-2026, 11:37.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Causes and Solutions Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Performance Loss Above 130 km/h (AJM) Diesel Engine Technology
