Turbo Pressure Sensor: Only 5V?
Puschkin2
Post07-08-2004, 12:00    Subject: Turbo Pressure Sensor: Only 5V? Quote
I just bought a Passat 98 with the AFN engine. It has absolutely no turbo boost. I initially thought it was the mass airflow sensor (MAF), but that wasn't the problem. I then checked the vacuum actuator for the turbo and cleaned it, but it still didn't work. Now I've discovered that there are only 5 volts at the pressure transducer on the turbo. Could the engine control unit (ECU) be faulty? I directly applied vacuum to the turbo, and it briefly produced some power.
Translated on 27-07-2026, 3:56.
brezelmann01
Post07-08-2004, 13:31    Subject: Turbo Pressure Sensor: Only 5V? Quote
If you had bothered to use the search function regarding the topic of wastegate valve and your issue, you would have INDEPENDENTLY found the answer icon_rolleyes.gif, as to what type of voltage is present there... AND: READ PROFESSIONAL ARTICLES!!!!
Does anyone actually pay attention to Rainer's preface anymore? icon_evil.gif
Dirk.
Translated on 27-07-2026, 3:57.
Manuel Thomas
Post07-08-2004, 16:24    Subject: Turbo Pressure Sensor: Only 5V? Translating...
[Translating...]Nicht Pin 1 gegen Pin2, sondern Pin 1 oder 2 gegen Masse messen!
Bei einem muß Batteriespannung anliegen!
Schaue auch hier: https://community.dieselschrauber.org/en/viewtopic.php?p=30666&highlight=#30666
Manuel
No new posts Charge pressure regulation for VTG turbochargers Diesel Engine Technology
No new posts Turbo Lubrication: Observations and Analysis Diesel Engine Technology
No new posts Air-cooled turbos: Which models are available? Diesel Engine Technology
No new posts Pressure Transducers: Types & Applications Diesel Engine Technology
