Hello!
Does anyone have an electrical diagram for a Skoda Octavia SLX, built 17.2.98, engine 1U?
I have purchased a GRA and would like to install it, so far so good.
I also purchased the cable harness for the GRA.
Okay, now my questions:
1. Has my Skoda already pre-wired the cable harness for the GRA, so that I only have to install the remaining {COMPONENT}?
Do I need to install GRA levers?
2. If not, you need to connect all 4 cables to the control unit, which is located under the windshield wiper motor, as there are only 2 connected in the attached diagram.
Furthermore, the attached drawing is of the Passat 97 (I don't know if it's the same for the Octavia).
The cables are labeled as:
K.A.1
K.A.2
K.A.3
K.A.9
The cables should be plugged into the 10-way socket (T10k).
Can anyone tell me what function each cable is intended for?
Thank you in advance.
I hope you don't mind me bringing up the GRA topic again, but I
I was unable to find the answer that was suitable for me in the search function.
