VP37 Job Opening: Apply Now!
Thomas
Post09-08-2004, 16:45    Subject: VP37 Job Opening: Apply Now! Quote
Unfortunately, I couldn't find the answer in older posts. Therefore, my question is: What setting should I use on a VP37 when adjusting it on an AFN engine (using a timing light), if the pump cover (flow control mechanism) has been moved?
Background:
I purchased a second VP37 from eBay, and the seller apparently tinkered with the pump and couldn't get the settings right anymore, so he sold it on eBay. According to the description, the pump was working perfectly until it was removed. icon_rolleyes.gif
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 09-08-2026, 17:52.
wolfi_b
Post10-08-2004, 7:40    Subject: VP37 Job Opening: Apply Now! Quote
I could find the measurements for you from my DIY book.
But I see a fundamental problem here: With the timing light, you can only control the injection timing. However, shifting the cover changes the amount [of fuel/air], doesn't it?
Or what exactly are you trying to check with the clock?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 09-08-2026, 17:53.
christians
Post10-08-2004, 17:29    Subject: VP37 Job Opening: Apply Now! Quote
Have you read the relevant article yet? I don't have much hope for your request.
Translated on 09-08-2026, 17:54.
Tuppie
Post10-08-2004, 19:17    Subject: VP37 Job Opening: Apply Now! Quote
In principle, the engine should start reliably if both settings are correct. However, both the MSW position on the ESP and the injection timing have relatively narrow tolerances. With a bit of luck, it might work, but it involves a lot of trial and error.
Please definitely read my more detailed article about the VP37, especially regarding parts from eBay. The previous owner might have damaged the pump, and you'll be testing it until winter. In your situation, I would definitely check the correct position of the camshaft and possibly verschandeln the MSW (multiple sensor unit) at the same time; that way, at least something useful will have been done.
And: take your time.
Tuppie.
Translated on 09-08-2026, 17:55.
Thomas
Post15-08-2004, 10:03    Subject: VP37 Job Opening: Apply Now! Quote
@wolfi_bViewing profile: wolfi_b
I could get you the measurements from my DIY book.
But I see a fundamental problem here: With the timing light, you can only control the injection timing. However, moving the cover changes the amount [of fuel injected], doesn't it?
Or what do you want to check with the clock?
It's possible that I misunderstood something. Until now, I thought that you could measure the piston stroke by looking at the indicator in the middle of the cylinders. Shouldn't this value also change if I move the MSW (Main Service Valve)?
Hintergrund: Mir ist vor einiger Zeit meine Einspritzpumpe gestorben. (Quantity adjuster: upper limit) Das MSW lies sich nicht reinigen und der RWS hing bombenfest. Due to a lack of time.
I removed the pump and installed a new one. The measurement of the stroke of the old, defective pump showed approximately 0.7 mm. However, the new pump has a stroke of 0.9 mm! (Despite this, there was still a slight loss of power, and I have no idea why!)
Due to the sluggish initial acceleration, I kept increasing the MSW (maximum slip wheel speed) until I reached the soot limit. Surprisingly, this limit was reached before the "bouncing" limit!
My thought was to simply adjust the MSW (mechanical swivel valve) using a measuring instrument to the value specified by Bosch for an AFN pump. Since all three pumps have the same VW part number, one is set to 0.7mm, another to 0.9mm, and the newest one is completely misadjusted.
I wonder what value actually needs to be achieved?
Have I forgotten anything, or am I making a mistake somewhere?
@christiansViewing profile: christians
Have you already read the relevant article?
Sure, I'm familiar with the article. But I haven't had that "aha!" moment yet!
@Tuppie
I adjust the start of injection by turning the pump, at least until the control system takes over. I'm confident that I can get it running. Ideally, I would like to be able to make the adjustments based on Bosch specifications and know for sure that the pump itself is working correctly!
Please definitely read my more detailed article about the VP37, especially regarding parts from eBay. The previous owner might have damaged the pump, and you'll be testing it until winter. In your situation, I would definitely check the correct position of the eccentric and possibly verschandeln the MSW (mechanical self-adjustment) at the same time; that way, at least something useful will have been done.
Did you mean the MSW cleaning article? I will also re-seal the pump as much as possible. I just bought a VP37 seal kit.
What could the previous owner have damaged or broken? Surely that would become apparent when disassembling it?
How do I check the correct position of the cam? Or better yet, how do I know what is right and what is wrong?
Greetings.
Thomas.
Translated on 09-08-2026, 17:59.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Engine tuning box installation Diesel Engine Technology
No new posts RWG-Position at AFN? Diesel Engine Technology
No new posts VAG Com - Easily make adjustments Diesel Engine Technology
No new posts Clutch Housing Plugs & NW Adjustment PD Diesel Engine Technology
