Analysis of a performance diagram...
Adrian
Post05-08-2002, 20:32    Subject: Analysis of a performance diagram... Quote
Can someone take a look?
Below, under 'Performance Charts,' you can view various 'images.' What exactly do you see there? A comparison of the power box and the stock configuration? Then the serial diesel engines would have had quite a bit of 'power' under the hood... http://www.tuningbox.com/DE/p4frframede.html
The 'smaller' torque curve of the 110-horsepower TDI engine already shows over 250 Nm.
Why is P.tol. - which I assume refers to tolerance - given as -16.7%? How can this value become negative?
Perhaps someone could translate this for me into German.
Thank you very much.
Adrian.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Log Analysis: Audi A6 2.5 BDG (3-8-11) On-Board Diagnostics (OBD)
No new posts End-Auswertung TDI-MKB-Statistik Diesel Engine Technology
No new posts Log File Analysis: Insights & Optimization On-Board Diagnostics (OBD)
No new posts Hilfe bei Messblock Auswertung On-Board Diagnostics (OBD)
