Let's get down to business! | Posts 16+
Go to page: Previous  1, 2
Rußerzeuger
Post25-08-2004, 22:51    Subject: Let's get down to business! Quote
Hi.
I don't really care for theoretical philosophical discussions about the 'to be or not to be' question!
Has anyone here ever tried poking small holes (sizes 1, 2, or 3) into the sensor hose to slightly increase the boost pressure in order to further reduce soot emissions?
The soot emissions have already decreased after I installed the AFN injectors, even though I expected the opposite. So, it seems like a small adjustment could make all Peugeots environmentally friendly, right?
Sebastian.
Translated on 17-08-2026, 17:26.
christians
Post26-08-2004, 11:46    Subject: Subject: Let's get to the point! Quote
Rußerzeuger wrote:
I don't really care for theoretical philosophical discussions about the "to be or not to be" question!
However, it can save you a lot of work and expensive damage.
Especially when it's clear that no one has ever tried something like that before.
Gruß Christian
Translated on 17-08-2026, 17:28.
Henrik
Post31-08-2004, 9:27    Subject: Subject: Let's get to the point! Quote
Sebastian
Okay, I'll just quickly get in touch.
I have a boost pressure gauge installed. Just for fun, I added a T-connector to it and attached a 10 cm long hose to the connector, with a crimp fitting at the end.
I've tried everything from allowing a lot to pass through to almost nothing, but it hasn't really made any difference.
The turbo either runs at a very minimal level or is fully engaged, making it difficult to control. Without holes and without a boost pressure gauge, it will be impossible to regulate the boost... so avoid using it, and instead, install a larger resistor behind the boost pressure sensor in the engine control unit!
Translated on 17-08-2026, 17:29.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts Turbocharger Oil Line Leak: Causes & Fixes Upload
No new posts Shorter LL Paths: More Power, Pipes vs. Hoses? Diesel Engine Technology
No new posts Boost Pressure: Does 20% More Mean 20% More RPM? Diesel Engine Technology
