Touareg documentation, clacking sounds coming from the steering column area (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post02-09-2004, 16:31    Subject: Touareg documentation, clacking sounds coming from the steering column area Quote
Clunking noises from the steering column area
Cause:
Increased play in the lower bearing of the steering mechanism.
Solution:
Loosen the screw at the lower bearing by a few turns, so that the bearing can move within the fixing block of the chassis mounting.
Do not completely loosen or remove the screw and nut.
Manually push the bearing forward in the direction of travel (without excessive force).
In this loosened state, tighten the screw with the specified torque.
TschĂŒss
Michael II
Ratings - Touareg documentation, clacking sounds coming from the steering column area
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Steering Column Transmission, Chassis, Body & Interior
No new posts Steering Column Warranty: What You Need to Know Diesel Engine Technology
No new posts Replace Steering Column U-Joints (G4/A3) Transmission, Chassis, Body & Interior
No new posts Steering Column Feather & Clip Diesel Engine Technology
