Clutch Not Disengaging: Causes & Fixes
Uwe
Post25-08-2004, 12:25    Subject: Clutch Not Disengaging: Causes & Fixes Quote
In my A3, the clutch is no longer disengaging properly, especially when the engine is hot. It starts to engage almost immediately.
After bleeding with air bubbles inside, unfortunately, there was no change icon_sad.gif.
After swapping both cylinders, it still looks exactly like this new_cry.gif.
Woran kann das liegen? Gibt es irgendwo Einstellmöglichkeiten? Clutch failure?
Uwe
Translated on 25-09-2026, 6:29.
Marco
Post25-08-2004, 12:30    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Hi Uwe,
Does the clutch still engage properly while driving? If, for example, the clutch disengages with a slight delay after the pedal is pressed, and the hydraulics are working correctly, it's possible that a faulty seal ring is causing oil to leak onto the clutch, which could cause it to stick.
Translated on 25-09-2026, 6:30.
Post25-08-2004, 12:43    Subject: Clutch Not Disengaging: Troubleshooting & Repair Quote
Uwe wrote:
On my A3, the clutch is no longer disengaging properly, especially when the engine is hot. It starts to engage even with the first millimeter of pedal movement.
I'm having a very similar problem.
When the engine is extremely hot (especially when towing), there's a loud bang when shifting from 4th to 5th gear.
If I wait a very long time before releasing the brake pedal after pressing the clutch, there's no grinding noise.
The clutch engages smoothly and relatively early.
I don't have any problems when shifting down.
Is that the same error you're experiencing?
Last week, I had the feeling that there was a smell of transmission oil after the car wash.
Translated on 25-09-2026, 6:31.
Uwe
Post25-08-2004, 12:56    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Marco wrote:
Hi Uwe,
Does the clutch still engage properly while driving? If, for example, the clutch disengages with a slight delay after the pedal is pressed, and the hydraulics are okay, it's possible that a defective seal ring is causing oil to leak onto the clutch, which could cause it to stick.
The clutch disc itself seems to be fine. There's no sticking or jerking. The problem is simply that the pedal travel is insufficient. If I release it even a millimeter, the car starts to move.
When the engine is warm, the pedal travel changes again, to my disadvantage, making it difficult to engage reverse gear.
Could it be due to the thrust bearing?
Uwe
Translated on 25-09-2026, 6:33.
Post25-08-2004, 13:37    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Steam bubbles in the receiver cylinder?
It really shouldn't get that hot there...
Translated on 25-09-2026, 6:34.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post25-08-2004, 17:56    Subject: Clutch Not Disengaging: Causes & Fixes Quote
B.Eng (FH) u. KFZ Meister
Uwe
Post25-08-2004, 18:39    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Thank you for the comprehensive answer!
Uwe
olli
Karma: +46 / -0   Thank you, like it!
Post25-08-2004, 22:20    Subject: Clutch Not Disengaging: Causes & Fixes Quote
It might be worth removing the slave cylinder and checking its function. Is it seated correctly in the transmission, or perhaps protruding too far? If this is an air bleeding issue, you'll usually notice it by an extremely light clutch pedal.
@BertilViewing profile: Bertil
The input shaft of the gearbox is mounted in a needle bearing on the flywheel side. If this bearing is damaged or starting to fail, the symptom you described could occur, as the shaft would still be driven even with the clutch properly disengaged. However, if only one gear is not synchronizing correctly, it's more likely to be a problem with the gearbox itself.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 25-09-2026, 6:35.
Post26-08-2004, 6:19    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Hi Olli,
olli wrote:
@Bertil
The gear input shaft is located in a needle bearing on the flywheel side. If this bearing is damaged or starts to deteriorate, the symptom you described could occur, as the shaft could still be driven even with the clutch properly disengaged.
... da hab ich noch gar nich dran gedacht ... Thank you.
I've been experiencing this phenomenon for over 10,000 kilometers.
Can this defect persist for so long?
However, if only one gear is not shifting properly, it's more likely to be a problem with the transmission.
Shouldn't that be more relevant/also come into play when shifting back down?
If the synchronization is faulty, wouldn't the problem be resolved by pairing twice? However, that doesn't work.
Translated on 25-09-2026, 6:37.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post26-08-2004, 7:32    Subject: Clutch Not Disengaging: Causes & Fixes Quote
It could also be due to hardened grease (or even a lack of grease), or contamination on the gearbox shaft, which I experienced once. The clutch wasn't disengaging properly, and there was a slight creaking sound every time I shifted gears. I could only engage reverse gear with the engine off. If the car is parked on a slope and you depress the clutch with the gear engaged, the car will still remain stationary. However, for this test, the car needs to be cold.
Here's a suggestion, although this was the case with the Golf 2 as well.
Translated on 25-09-2026, 6:39.
Uwe
Post07-09-2004, 17:30    Subject: Clutch Not Disengaging: Causes & Fixes Quote
Okay, the old clutch is out, and the new one is in.
Two friction plates had disintegrated and were floating around inside the clutch bell as debris.
Now it shifts properly again and is also easier to use. The only thing that's not working is the cruise control, but I think I can fix that.
Uwe
Translated on 25-09-2026, 6:40.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Not Disengaging: Causes & Fixes Diesel Engine Technology
No new posts Clutch Not Disengaging? Get Help Now! Diesel Engine Technology
No new posts Hydraulic Clutch Audi A3 8PA 2.0 TDI Not Disengaging Transmission, Chassis, Body & Interior
No new posts Lupo SDI Clutch Problems: Not Disengaging? Diesel Engine Technology
