ESP, ALH engine leak
Pöbel
Post19-09-2004, 18:35    Subject: ESP, ALH engine leak Quote
I've been running my Octavia on vegetable oil for about 2000 km (1-tank conversion by Elsbett). Before that, I used biodiesel. The current mileage is approximately 42,000 km. The ESP is leaking, probably between the distributor head and the pump housing. icon_cry.gif Can this be repaired yourself with a gasket set? Or can Bosch do it? Or is replacing the entire pump the only option? Why could this leak have occurred?
Mob.
Translated on 15-07-2026, 22:13.
Post19-09-2004, 19:48    Subject: ESP, ALH engine leak Quote
Hey folks,
It's a shame you didn't bother to educate yourself about biodiesel and engine conversions before trying them.
The leak is likely caused by the biodiesel. Finding a Bosch service to repair it (by replacing the seal(s)) might be a bit more difficult. You'll probably need to find some experienced mechanics for that. Usually, these ESP units are replaced entirely (which is unfortunately expensive).
-> There are already several posts on the search function related to topics like biodiesel and replacing the sealing ring.
Translated on 15-07-2026, 22:14.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Leaky Heater Valve - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts ESP undicht / Dichtungen Diesel Engine Technology
No new posts Exhaust manifold leak, BKD engine Diesel Engine Technology
No new posts Defective candle Diesel Engine Technology
