Vorförderpumpe - Passat AFN! | Posts 16+
Go to page: Previous  1, 2
Post15-09-2004, 19:50    Subject: Quote
audi200 wrote:
or do you have any idea how such a difference might arise?
-> Communication/compatibility issue with VAGCOM and the car?
-> Reading error (did you miss a comma?)?
Translated on 24-08-2026, 9:36.
audi200
Post15-09-2004, 20:02    Subject: Quote
I don't think it was a reading error; unfortunately, I didn't take a Screenshot. Maybe I will later.
I also don't think it's a communication or compatibility problem with VAGCOM. It's a Passat built in 1998 and, as I said, the engine code is AFN.
audi200
Post20-09-2004, 18:02    Subject: Quote
Thank you again to everyone who responded!
This weekend, I looked into some other things that I read about here.
- The pump in the tank is only responsible for balancing the pressure between the individual chambers; it has no connection to the pump's suction line.
- Intake manifold cleaned, but normal deposits were present, nothing that would indicate a problem with the engine's operation.
- Fuel intake line bypassed (filter disabled), no change.
- I rechecked the LMM (mass airflow sensor) using VAG Com measuring block 000/10, which showed a full load value of 255. I also measured it with a multimeter and got 4.22 volts at approximately 4100 RPM.
- Loading pressure exceeding almost the entire range of 2100 mbar, with a slight overshoot at the beginning.
up to approximately 2250 millibars.
- The other values in the various measurement blocks were also generally within acceptable limits.
at least, according to the comparison list from here.
- Fuel injectors removed and visually inspected; no signs of deposits or anything like that. The only issue remains the significant cylinder deviation readings according to the VAG Com diagnostic tool.
Regarding the fuel injectors, I have a question: Has anyone ever experienced a failure with them?
where performance was compromised without the engine producing excessive soot? In fact, faulty injectors usually become apparent due to significant soot production!
Best regards.
Audi 200.
Translated on 24-08-2026, 9:39.
Manuel V
Post21-09-2004, 17:52    Subject: Quote
Hello fellow enthusiasts,
I need to revisit the issue of the fuel pump and surge tank. I'm getting a 'fuel injection timing error' (code 550) whenever the engine is warm, especially after a long drive under heavy load. When I check the supply line and tap on the filter, there's a lot of air in it. I replaced the diesel filter and tightened all the clamps. While bleeding the system, I noticed that I could only draw diesel through the return line; the supply line created a massive vacuum. If I block the supply line leading to the tank, no diesel can be drawn through it. If the pump is only filling the surge tank, shouldn't the supply line be completely blocked? Or does the VP44 have something else that could obstruct bleeding? As far as I know, there isn't a manual valve for this.
Best regards, Manuel.
Translated on 24-08-2026, 9:42.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pre-Pump Pressure: Measurement & Optimization Diesel Engine Technology
No new posts Diesel Pre-Pump: Upgrade Options & Compatibility Diesel Engine Technology
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
