Audi A6: How to Replace Turn Signal Relay
fbeera
Post23-09-2004, 9:30    Subject: Audi A6: How to Replace Turn Signal Relay Quote
Hello everyone,
The turn signal relay in my 1998 A6 sometimes fails.
Friendly reminders are becoming less effective as the area (not this icon_wink.gif) around the hazard light switch is repeatedly tapped...
So, I'd like to switch things up with the team members...
But how do I get to it? How do I remove the drawer/cup holder unit? Apparently, I'm too stupid to figure it out...
Please help me get on the horse icon_wink.gif).
Thank you and best regards, Frank.
Translated on 30-09-2026, 10:08.
Aliensafari
Post23-09-2004, 10:19    Subject: Audi A6: How to Replace Turn Signal Relay Quote
The expansion is relatively simple:
Carefully pry off the cover. It is only clipped in place. Then you can remove the hazard light relay. If necessary, use a small screwdriver to push the retaining tabs back on the left and right sides. However, it should come out easily without that.
However, in 80% of all cases, problems with the turn signal relay are caused by the steering column switch! That's where the electronics are located. The hazard light switch (which also houses the 'small' turn signal relay) is definitely working correctly.
Hopefully, this has been helpful.
Marco.
Translated on 30-09-2026, 10:10.
fbeera
Post24-09-2004, 9:52    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
Yes, thank you very much for the help with the horse icon_wink.gif).
Hmm, I wouldn't suspect the steering column switch. Just because sometimes, by gently tapping in the area of the relay, you can sometimes restore the function...
But I'll also keep an eye on the steering wheel, and I'll let you know what I find.
Thank you very much for the horse assistance icon_wink.gif).
Best regards, Frank.
Translated on 30-09-2026, 10:11.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Blinking Relay Noise: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Remove ESP? Troubleshooting & Installation Guide Diesel Engine Technology
No new posts A4 2.0 TDI Oil Line Removal: BPW Guide Diesel Engine Technology
No new posts Removing fuel injectors Diesel Engine Technology
