1.6 TD Catalytic Converter Retrofit?
Rudis
Post28-09-2004, 16:56    Subject: 1.6 TD Catalytic Converter Retrofit? Quote
Regarding the situation, I looked at a Golf 1 today with a 1.6 TD engine (51 kW). The owner said that the car doesn't have a catalytic converter.
Is it possible to retrofit a catalytic converter to a vehicle and potentially achieve Euro 2 emissions standards? If so, does anyone have the contact information for a dealer who sells catalytic converters?
Oh yeah, the Golf originally had a 40 kW engine, but I've converted it to use a 51 kW engine.
Translated on 04-10-2026, 14:58.
Post28-09-2004, 17:02    Subject: 1.6 TD Catalytic Converter Retrofit? Quote
First, you should find out which TD it is.
Is the JR from a Golf 2, or from the... um... the original TD Golf, which was called something else?
Then you can check out websites like Oberland and similar companies to see if they have anything you're looking for.
Translated on 04-10-2026, 14:59.
Rudis
Post28-09-2004, 19:18    Subject: 1.6 TD Catalytic Converter Retrofit? Quote
The tip about the Upper Bavarian region was great!
Thank you.
For the 51 kW engine (with engine code CY) in the Golf 1, it is possible to retrofit it to meet Euro 1 emissions standards. For the JR engine in the Golf 2, it is possible to retrofit it to meet Euro 2 emissions standards.
Thank you for the quick help.
Best regards, Rudi.
Translated on 04-10-2026, 15:00.
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Retrofit for RME Vehicles Diesel Engine Technology
No new posts AHK Retrofit Programming: Guide & Tutorial On-Board Diagnostics (OBD)
No new posts TDI Catalytic Converter Retrofit by VAG? Diesel Engine Technology
No new posts Oil Temp Retrofit for MFD Systems Diesel Engine Technology
