Omega 2.5 TD has poor starting performance.
nsu1200c
Post02-10-2004, 16:16    Subject: Omega 2.5 TD has poor starting performance. Quote
Hello...
I have a problem with my 2.5L TD in my Omega (6 cylinders). BMW)
When he's standing still and cold, it only kicks in after prolonged orgasms.
He stands in the entryway with his snout down, and he jumps up really well.
If I open the drain valve at the filter end while playing the organ, only air comes out first.
So, I replaced the fuel pump in the tank, but the same problem persists. The spark plugs are new.
I don't know what to do anymore and I'm really fed up (with this piece of junk Opel).
Who can help???
(I have already switched to a T4 TDI, but I need to get rid of the Opel)
Best regards
Thomas
Post02-10-2004, 17:15    Subject: Omega 2.5 TD has poor starting performance. Translating...
[Translating...]
das Problem hatten wir schonmal hier im Forum, damals war es irgend ein Japaner der perfekt ansprang wenn die Schnautze nach unten stand, auf der Geraden sprang er nicht an. Wenn ich mich recht erinnere gab es da Probleme mit der Tankentlüftung, bzw zog die ESP auf der Strecke Tank ESP irgendwo Luft an. Schau mal alle Verbindungen bis zum Filter und der ESP genau nach. Auch den Rücklauf überprüfen
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Transporter 7D, Schiebetüre schließt schlecht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia springt schlecht an (MKB: AGR) Diesel Engine Technology
No new posts AFN springt warm schlecht an Diesel Engine Technology
No new posts A5 3,0 TDI springt sporadisch schlecht an, MKB: CAP Diesel Engine Technology
No new posts Audi TDI AEL springt schlecht an Diesel Engine Technology
