eike Guest
06-10-2004, 7:51 Subject: Car Tuning: Online & Thermoelectric Power Generation |
I just received a newsletter with interesting content.
'Firstly, a USB-connected EEPROM emulator is offered, which could be interesting for online tuning. Secondly, it concerns thermoelectric energy generation, which could potentially be used in cars in the future.'
But see for yourselves, or rather, read for yourselves:
- New product - particularly interesting for the tuning sector:
The USB EEPROM emulator is suitable for all areas where...
to which the data of a target system is 'online' during operation.
The device is to be modified. It will replace the existing...
emulating chips are directly inserted into its casing, and the...
Data can be transferred via the USB connection during operation.
Adaptable for PC/laptop use. More information can be found [here/below/elsewhere].
She is under:
http://www.progshop.com/versand/epromemulator/emulator.shtml
2. New material efficiently converts thermal energy into...
to convert electrical energy into...
The heat generated by the internal combustion engine may not need to be released in the future.
more of it goes to waste. American researchers have developed a material...
developed to convert thermal energy more efficiently into electrical power.
can be converted into electricity more efficiently than ever before. The electricity generated...
could even cover the entire electricity demand of a car, we hope.
Mercouri Kanatzidis from Michigan State University in East.
Lansing and his colleagues. This is reported by the British...
Wissenschaftsmagazin New Scientist (Ausgabe vom 4. Sept., p. 34).
The idea is to generate electrical energy using a temperature difference.
winning, is not new. Previous methods for utilizing thermo-
elektrischer Energie waren jedoch sehr ineffektiv. The problem.
consists of the fact that conventional electrically conductive materials also...
Transfer heat. This reduces the temperature difference.
and it is no longer possible to generate electricity.
Certain so-called thermoelectric materials, while...
However, electrons, and therefore electricity, have a significantly lower...
Thermal conductivity. The one developed by Kanatzidis and his team...
Materials made from antimony, lead, silver, and tellurium can release...
Temperature difference of approximately 600 degrees Celsius, which is about 18 percent.
Convert thermal energy into electricity. That would be an excellent conversion rate.
says Kanatzidis.
Unlike conventional thermoelectric materials,
which are assembled using a complex layering process.
'Is this the mixture developed by Kanatzidis and his colleagues?'
Furthermore, it is easy to produce. In the alloy, silver and...
Antimony forms tiny islands within a sea that is mostly lead.
and consists of tellurium. These nanostructures are used for the...
Heat conduction is governed by phonons, while electrons are scattered.
not, researchers suspect. Thermoelectric materials.
can be applied in many areas. For example, they could be used to...
Temperature differences in ship turbines or power plants for [purpose].
Harnessing electricity generation.
'Links to the article:'
University of Michigan: http://www.msu.edu/
New Scientist: http://www.newscientist.com/
Sure, please provide the text you would like me to translate from German to English. I will provide only the translation, without any explanations.
The website for electronics developers and hobbyists!
www.batronix.com - Construction manuals, downloads, and technical expertise...
Greetings.
Eike.
Translated on 20-10-2026, 17:55.
chris11 Profi-Schrauber
Joined: 10/02/2002 Posts: 326 Karma: +3 / -1 Location: Münster
06-10-2004, 9:55 Subject: Car Tuning: Online & Thermoelectric Power Generation |
The use of emulators is absolutely not permitted. Following several accidents, this has...
To the best of my knowledge, the KBA (German Federal Motor Transport Authority) has even prohibited vehicle testing on public roads for vehicle manufacturers.
In the event of an accident, it will most likely be the worst-case scenario from an insurance perspective.
Regarding the conversion of temperature differences into mechanical power, developers of diesel and gasoline engines have been desperately trying for over a hundred years to achieve an efficiency of around 40% for automobiles. Achieving 18% with new thermoelectric elements is still not a breakthrough.
Christian.
Translated on 20-10-2026, 18:01.
Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
06-10-2004, 13:30 Subject: Car Tuning: Online & Thermoelectric Power Generation |
chris11 wrote: | Hello,
Christian |
The comparison is a bit flawed because those 18% are in addition to the energy, and they might potentially replace the LiMa (lithium-ion batteries). You can consider these 18% as a step towards increasing your overall efficiency of 40%.
Why not simply use a small Stirling engine to convert the temperature difference into work?
The 18% figure mentioned in the article only applies to a temperature difference (Delta T) of 600K. Where else do our TDI engines produce such high values, other than directly at the turbocharger inlet (where they are actually needed)?
Who knows what temperature the exhaust gases are after they have done work on the drive wheel from the turbocharger?
(And who quickly calculates the additional work gained, considering the exhaust gas flow rate of xxx, the temperature difference of yyy, and the efficiency of the Stirling engine?)
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Translated on 20-10-2026, 18:04.
Profile PM Garage |
