Cable Tie Tool: Installation & Removal
Animalking
Post15-08-2002, 0:33    Subject: Cable Tie Tool: Installation & Removal Quote
I have a Golf IV TDI PD ATD with 100 horsepower!
I would now like to disconnect the intake hose in front of the EGR valve!
Is this attached with spring clamps? Are there any good tools for removing spring clamps, especially in hard-to-reach places in the engine?
Thank you.
Translated on 11-09-2026, 20:57.
Jürgen
Post15-08-2002, 12:06    Subject: Cable Tie Tool: Installation & Removal Quote
HAZET offers a pair of pliers with a mechanism connected to a Bowden cable, but they are quite expensive.
The function is really great!
Due to part number: www.hazet.de
Jürgen
Translated on 11-09-2026, 20:58.
Post15-08-2002, 13:06    Subject: Cable Tie Tool: Installation & Removal Quote
A simple water pump pliers have been sufficient for me so far. I don't want to buy a specialized pliers because you can't really use them for anything else.
I would anyway replace the frequently loosening hose clamps with hose clamps, because the connection between the turbocharger and the pipe to the intercooler has already come loose on its own twice in my case. With the hose clamp, it's now stable.
Translated on 11-09-2026, 20:59.
Animalking
Post15-08-2002, 17:31    Subject: Cable Tie Tool: Installation & Removal Quote
If I have now loosened a cable tie, I can...
'Then reuse it to secure the pipe? Do you perhaps need a special tool for that? Or is it not recommended to reuse hose clamps (should you use screw clamps instead)?'
What do you think of the tool http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=2045801781?
Sure, here's the translation:
'Thx' is a shortened form of 'thanks.' It's often used in informal online communication, such as text messages or social media posts.
Translated on 11-09-2026, 21:00.
Post15-08-2002, 18:40    Subject: Cable Tie Tool: Installation & Removal Quote
Yes, of course, you can reuse the cable ties, but the question is whether they still hold securely after multiple uses icon_smile.gif.
The connection I mentioned has now proven to be critical, and it's the only one I've replaced with a hose clamp.
I'm not quite understanding your problem. Surely you have a pair of adjustable pliers? If not, you won't go broke buying one, and that tool is always useful (unlike a specialized plier).
Translated on 11-09-2026, 21:01.
