White smoke from engine: Causes & fixes.
TLuv
Post11-10-2004, 21:48    Subject: White smoke from engine: Causes & fixes. Quote
Hey everyone, I need your advice again.
Okay, so my brother-in-law has a terrible problem with white smoke coming from his Audi A6 2.5 TDI quattro. I've noticed that the white smoke only appears when the engine is warm, around 90°C, and when the car is idling. I let the engine run, and it produces a huge cloud of smoke, which is really bad. Also, it smells like oil, although I'm not completely sure.
My brother-in-law uses 15W40 oil and has been topping it up with 0W30 for a while. I thought that might be the problem, but we changed the oil, and it didn't improve anything. It's still smoking like a fog machine.
Do you have any ideas?
Translated on 05-09-2026, 5:16.
donalexo
Post11-10-2004, 21:54    Subject: White smoke from engine: Causes & fixes. Quote
icon_arrow.gif Search engine: Pump setting, injection start, delivery start, white smoke.
Touran 1.9 TDI, EZ 09/2004
Translated on 05-09-2026, 5:17.
Post12-10-2004, 10:26    Subject: White smoke from engine: Causes & fixes. Quote
"Furthermore, the information regarding oil or coolant consumption is missing!"
seabauer
Post12-10-2004, 14:46    Subject: Good Advice: Tips & Recommendations Quote
It sounds similar to what I experienced with my A4 2.5 V6 TDI, manufactured in 1998 with 150 horsepower, especially when the engine is cold.
absolutely nothing, roughly from 80-90 degrees, and then it's just absolutely terrible icon_rolleyes.gif.
It smells strongly of burnt oil, and the smoke disappears when you start driving.
Solution: A filter is installed in the crankcase ventilation system (a part that costs €30), which is connected to...
As the engine ages, the crankcase pressure increases, leading to oil leaks at the engine seals and resulting in smoke. In the worst-case scenario, the crankshaft oil seal can even be forced out.
There's nothing you can do yourself; the filter is located under the pump and turbocharger icon_cry.gif.
For me, everything was fixed immediately after replacing the filter, including the oil consumption.
It ended up being around 1 liter per 6,000 kilometers for me.
Greetings.
Translated on 05-09-2026, 5:19.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug: Why It's On With Warm Engine? Diesel Engine Technology
No new posts BMW 325 tds; Starts poorly when the engine is warm + Weak... Diesel Engine Technology
No new posts White Smoke: Understanding the Process Diesel Engine Technology
No new posts White smoke at approximately 3000 RPM Diesel Engine Technology
