How to make longer VTG rods.
SeatLeon
Post21-10-2004, 13:25    Subject: How to make longer VTG rods. Quote
I have an ALH engine with a chip and a boost pressure that goes up to just under 1.6 bar icon_eek.gif, and it's regulated between 1.2 - 1.3 bar. The boost pressure seems a bit too high to me. Now, I want to make the VTG linkage a bit longer. Can someone explain to me how to do this and what steps are involved? Do I need any special tools?
Thank you!
Post21-10-2004, 13:28    Subject: How to make longer VTG rods. Quote
A useful addition would be a diagnostic system that allows you to observe the filling process, or a pressure gauge, which you probably already have.
There's not much else to say: you can see everything when you look at the adjustment rod.
By the way, 0.5 to 2 rotations make a huge difference and should definitely be enough. Okay, just keep it simple.
SeatLeon
Post21-10-2004, 13:45    Subject: How to make longer VTG rods. Quote
In which direction should I turn now, downwards or upwards? Can I do this manually, or do I need a key?
Post21-10-2004, 14:03    Subject: How to make longer VTG rods. Quote
SeatLeon wrote:
In which direction should I now turn, downwards or upwards? Can I do this by hand, or do I need a key?
If you don't have adjustable wrench jaws, you'll need a wrench (usually 10mm).
You'll have to figure out yourself how your specific charger is set up (whether the canister is standing or hanging, and the design of the adjustment mechanism – for example, it might be different between Garrett and KKK).
No new posts Am VTG Gestänge drehen? Diesel Engine Technology
No new posts Bora AJM: VTG-Stange länger drehen - Bitte um Hilfe Diesel Engine Technology
No new posts Not a preferred gear ratio, but approximately 3.5% longer. Diesel Engine Technology
No new posts VTG-Gestänge einstellen Diesel Engine Technology
