Fuel Injector Nozzle Size 0.216mm - 2.5L
z-man
Post23-10-2004, 0:22    Subject: Fuel Injector Nozzle Size 0.216mm - 2.5L Quote
Looking for the part number of the fuel injectors for a 2.5L engine with a 0.216mm hole diameter! They need to fit into an AHF engine!
'Micha'
Translated on 01-11-2026, 16:31.
Post23-10-2004, 1:26    Subject: Fuel Injector Nozzle Size 0.216mm - 2.5L Quote
Search for "216 number".
You can find information there that indicates you are looking for the Duesem of AXG.
Then search for the "AXG part number," and you will encounter some numbers.
Also, your VW dealer will be able to tell you the number, or anyone else who sells you those parts.
074 130 204 C
074 130 201 T
Translated on 01-11-2026, 16:32.
Achim
Post23-10-2004, 18:59    Subject: Fuel Injector Nozzle Size 0.216mm - 2.5L Quote
Alternatively, the injectors from the AHY engine might also be compatible, as it's also a 111 kW T4 engine.
074 130 201 K
074 130 202 R
Translated on 01-11-2026, 16:33.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Injector Nozzle Size 1Z: Diameter Guide Diesel Engine Technology
No new posts Part Number Original PD Fuel Injectors Diesel Engine Technology
No new posts Fuel Injector Part Number: Find Yours Now! Diesel Engine Technology
No new posts Practical values: 0.216mm nozzles in AFN Diesel Engine Technology
