Climate Control A4 Malfunction?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Bolzer
Karma: +14 / -0   Thank you, like it!
Post24-10-2004, 21:37    Subject: Climate Control A4 Malfunction? Quote
Hi.
I'm having a problem with my A4 TDI (year 1996) that has automatic climate control. When the car is parked for an extended period (3-4 hours), the air conditioning works perfectly fine (set to around 22°C) until the engine and interior warm up. Then, it only blows cold air into the cabin. There are no error codes stored, and I've already performed the basic reset procedure. Perhaps someone has another idea what could be causing this.
Best regards, Bolzer.
Translated on 14-08-2026, 1:07.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post25-10-2004, 19:18    Subject: Climate Control A4 Malfunction? Quote
Does the fan only blow cold air when the compressor is running, or also when it's turned off?
Perhaps check the temperatures using measurement blocks to verify their plausibility.
B.Eng (FH) u. KFZ Meister
Translated on 14-08-2026, 1:08.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 GRA spinnt Diesel Engine Technology
No new posts Temperaturgeber G62 spinnt Diesel Engine Technology
No new posts Another TDI acting up... Diesel Engine Technology
No new posts el. Aussenspiegelverstellung spinnt Transmission, Chassis, Body & Interior
