Lucas Fuel Injection Pump
JRX001
Post20-08-2002, 22:13    Subject: Lucas Fuel Injection Pump Quote
hello everyone,
I'm probably in the wrong place, but it's worth a try.
Does anyone have any knowledge of the Lucas fuel injection pump, specifically as used in the Fiat TD100?
I have the following questions:
- Can I advance the injection timing on this purely mechanically controlled pump?
- and modify the control behavior.
I would also be very grateful for any literature recommendations.
greetings
Jörg.
Translated on 02-09-2026, 6:57.
Post21-08-2002, 18:46    Subject: Spritzstart: Tipps & Tricks für den perfekten Start. Quote
Hi.
In purely mechanical pumps, it should be possible, in my opinion, to initiate the start of pumping (and thus the start of injection) by using the traditional method of twisting the pump.
Unfortunately, there's no injection pressure adjustment voltage that would indicate the "success" of the action. That is, you have to measure the stroke of the injection plunger using a special device, as was the custom among old-school mechanics.
For the throttling behavior, there might be adjustments available, possibly but perhaps inside the pump icon_sad.gif.
Translated on 02-09-2026, 6:58.
No new posts Sealing the injection pump on a AAT 2.5 TDI? Diesel Engine Technology
