V6 TDI: Performance Issues After Camshaft Replacement
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
altonno
Post29-10-2004, 12:32    Subject: V6 TDI: Performance Issues After Camshaft Replacement Quote
Hello everyone,
After I replaced the camshafts on my V6 TDI (more about that here: http://www.passat3b.de/phpBB2/viewtopic.php?t=24537&highlight=), it's now experiencing performance issues. Specifically, it can only reach 200 km/h, and it takes a very long time to reach that speed. With the "broken" camshafts, it ran without problems, reaching 230-240 km/h according to the speedometer. What could be the cause? I made sure the timing belt was correctly aligned, with the camshafts, pump, and crankshaft properly synchronized, and then I tensioned the belt, following the repair manual. The only thing I haven't done is adjust the fuel injection pump. The diagnostic tool shows 0° advance, while the target value according to Audi is 2° retard, plus or minus 2°. Could this make such a difference, or where is the problem? I'm grateful for any advice.
Al.
Translated on 19-10-2026, 9:12.
Marco
Post29-10-2004, 13:11    Subject: V6 TDI: Performance Issues After Camshaft Replacement Quote
If the belt settings are correct, then the only thing left to check is the ESP (Electronic Stability Program).
Regarding VP44 injectors that are not properly calibrated, yes, that can make a significant difference, and they should be calibrated correctly.
Translated on 19-10-2026, 9:14.
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKF Motor: Performance Issues & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Camshaft Replacement Problems: AKE Issues. Diesel Engine Technology
No new posts V6 TDI AKN issues with setting the injection timing using... On-Board Diagnostics (OBD)
No new posts SDI AKU: Engine Misfires After Start, Power Loss Diesel Engine Technology
No new posts Engine Performance Issues After Timing Belt Replacement Diesel Engine Technology
